Compressor HF 21G $150ish instore w/20% off coupon
  • saidiadude
    • Oct 2005
    • 33
    • CA, USA.
    I Just posted this on FW:
    Just bought this compressor at Harbor Freight in store:
    http://www.harborfreight.com/cpi/cta...emnumber=47065
    Cost: $169.99 - 20%coupon + 1.79 + 1.79 (2 bottles of compressor oil at 10% off)+ CA Tax
    Total: $151.08
    I bought the 120volt, but there's a 230v for the same price in store.
    Details:
    From HF website:
    21 GALLON, 115 PSI CAST IRON VERTICAL
    Built-in Universal Quick Connect Coupler for Convenient Air Hose Connection
    * Heavy duty 3HP rated motor
    * 3.5 SCFM @ 90 PSI; 8.8 SCFM @ 40 PSI
    * Long-life oil lubricated compressor with precision machined cast iron sleeve
    * Twin capacitor motor with thermal overload protection
    * Wheel kit with 6'' wheels and ergonomic handle for smooth portability
    * Oil level indicator window for easy maintenance
    * Reduced vibration with rubber foot stabilizers
    120 volt, 60Hz; Shipping weight: 152 lbs.
    ITEM 47065
  • bigstick509
    • 1227
    • Macomb, MI, USA.
    Good Buy
    I've had this model for about 2 years now and have had no complaints.The price is as low as I have seen it in the last year. Overall, not bad for the price.
    • Lonnie in Orlando
      • 649
      • Orlando, FL, USA.
      I bought the 21-gal compressor last mo, also with 20% coupon. I bought it to replace my 8-gal HF compressor. So far, I believe it is a much better compressor and more useful size than the 8-gal. I'm surprised how much longer it can puff before recycling. It's quieter than the smaller compressor, too. Comes with a 25' cord. It gripes me to do so, but I bought an extended warrenty for it. See below for reason.
      Now for info on the 8-gal compressor #90385. This is the one that's available only on-line or catalog. A little more power and better specs than the 8-gal in HF retail stores. This is my third one (I returned it twice). One arrived broken; one wouldn't start; this one has failed, too. HF is refunding my $$.
      My opinion --
      1) don't buy heavy items from HF mail order, because they are too difficult to repack for return.
      2) #90385 doesn't get my seal of approval.
      3) in spite of somewhat lax QC, Harbor Freight has always demonstrated good customer service to me.
      - Lonnie
      • saidiadude
        • Oct 2005
        • 33
        • CA, USA.
        Thanks for the feedback guys. I plugged it in today and ran it for a few minutes. Left it on most of the day and it wasnt leaking air. When I purged the air from the top, there was some moisture in it (I realize this is normal). But when I opened the valve at the bottom, no water came out but a small amount of dry sandy substance came out - the equivalent of 3 or 4 drops of water. Is this normal?
        Happy with the quality so far. One washer for the wheels was malformed, but I am not concerned. It seems to be very well built overall. The rubber feet are not going to last long - they already looked very compressed after a few minutes on the concrete. Any of you guys have probs with the feet on the compressor?
          I too have one and it has worked fine, mine is about 2 years old.
          • Hank Scorpio
            • 18
            • Lansdale, PA
            • Unisaw
            Would this be enough of a compressor to run a HVLP gun?
            • pecker
              • Jun 2003
              • 388
              noise level
              Would any of the owners of this HF model know if it is any quieter than the typical "oil-less" models of similar size, such as those red ones with a Craftsman label?
              I have a 20 gallon Craftsman in the basement, and when it starts up it's REALLY LOUD.
