I know its not the lowest it's been but it has been up at $200 for a while so I thought I just put it out there for someone who might have been on the fence about it. Don't forget 10% off. And there's also a $15 off coupon on the back of the Amazon catalog (the one with the guy with the power washer on the front). So with all that we're talking $129. Not a bad price for the big green machine.
hitachi m12V back down to $159.99
Tags: None
Hold On
I think that the price should come down even lower, Hitachi has just released a new 3HP model.
"It's not the things you don't know that will hurt you, it's the things you think you know that ain't so." - Mark TwainComment
I agree with Mike it probably will drop again. It's always a guessing game though between when the price might drop again, when they pull the plug on the 10% off and when the $15 code expires (6/26). Just thought I would put it out there.
Sorry but the code I have is one time use. After getting burned on this a couple of times the first thing I do now is check the Amazon catalog cover to cover. I always save mine now for several months just in case....Don't be stupid, the universe is watching.Comment
New Model
M12V2 3-1/4 Peak HP Router, Plunge, EVS
* Features
* Specifications
* Powerful 15 Amp motor delivers top of class cutting speed to rout through hardwoods with ease
* Soft start motor produces 3-1/4 peak HP, while reducing torque during start up
* Equipped with an electronic variable speed dial, the M12V2 produces 8,000- 22,000 RPMs for a wider range of cutting applications and a wider range of materials
* Variable speed dial is conveniently located on the handle so the user can finely adjust the rotation speed without removing a hand or eyes from the work piece
* Unique quick & fine adjustment knob combines both functionalities into the same mechanism to quickly and accurately dial plunge depths
* Easily converts to table use
* Bits can be easily changed from a table mounting as the collet chuck is designed to protrude 6mm from the upper side of the table
* Equipped with an improved collet chuck that secures the bit into the armature shaft for maximum hold
* Dust guide diverts dust and debris away from the work piece and user
* Weighs 13.9 lbs making it safe and stable for freehand routing
* Ergonomic design for enhanced comfort and control
* Elastomer covers the handles to reduce transfer of vibration and prevent slippage
Includes:
* Straight Guide (956797)
* Centering Gauge (325233)
* Dust Adapter (325215)
* Guide Bar (325216)
* Wing Bolt (301806)
* Wrench (323293)
* 1/4" Collet (323293)
* 1/2" Collet (301795)
