Freud LU87R010 10" x 24-Tooth, 5/8" Arbor Perma-SHIELD Coated Thin Kerf Saw Blade$25
  • Aiko
    • 7
    Please note that the price of Freud LU87R010 10" x 24-Tooth, 5/8" Arbor Perma-SHIELD Coated Thin Kerf Saw Blade has decreased from $34.99 to $24.99 since you placed it in your Shopping Cart.
    Freud LU83R010 10" 50 Tooth Thin Kerf Combination Blade for 29.99
    http://www.amazon.com/gp/product/B00...lance&n=228013
  • AlanWS
    • 257
    • Shorewood, WI.
    That's a spectacular price for an excellent blade. I use the LU83R010 for most purposes these days. The LU87 also appears to be a good rip blade, but I have not needed to rip large amounts of stock since I got it.
    Alan
    • Knottscott
      • 3815
      • Rochester, NY.
      • 2008 Shop Fox W1677
      Those are both great prices and both excellent value choices for the BT and any saw under 3hp.
      • dave6
        Thanks for the tip Aiko, just ordered the Freud LU83R010 10" 50 Tooth. I've been looking for a not-too-expensive extra blade for my BT3100.
        • davidtu
          • 708
          • Seattle, WA
          << Newbie alert!
          Amazon description says:
          "Specially formulated micrograin carbide teeth slice quickly and easily through 3/4" to 2 3/4" inch thick hard and soft woods."
          The BT of course can cut dimensional 4x4--does this imply that using this saw one would not be able to use the max capacity?
          • Aiko
            • 7
            I don't think that is really implied, but does the saw have the power to turn the blade through that much wood. I have a rigid ts2400, and was using an infinity tools full kerf rip blade to rip some white oak? 4x4 that I got when the town installed new water mains. The saw grunted and cut, but required a good amount of pressure to push the wood thruogh. I wouldn't want to work it that hard alot, I think it would eventually burn the motor up. I ordered these blades to see if they work any better.
            • Knottscott
              • 3815
              • Rochester, NY.
              Freud recommends 3-5 teeth in contact with the wood for ripping applications. For 4" stock they'll recommend a very low tooth count blade. That doesn't necessarily mean other blades won't "cut it", but they're likely to burn and bog a bit, depending on the wood and setup.
