$35 impact driver
  • AlanWS
    • 257
    • Shorewood, WI.
    $35 impact driver
    The 14.4V HF impact driver ITEM 92472-3VGA is listed on the website at $35.
    http://www.harborfreight.com/cpi/cta...emnumber=92472
    If it works, that would be the cheapest impact driver I've seen. Does anyone know if this is actually a decent buy, or where one could find a better one at a price under $100 now? I know people have found great deals in the past, but have not seen anything currently available at a price close to this.
    Thanks.
    Alan
  • messmaker
    • 1495
    • RICHMOND, KY, USA.
    • Ridgid 2424
    Probably worth a shot. I have one from Black and decker and it is one of my favorite tools. The torque # sounds about right.
    • buckeye95
      • 267
      • Columbus, Ohio.
      • Ridgid TS2400
      I read a review on another forum about the HF cordless impact drivers a while back. As I recall, this one was rated decent, but the 18 Volt one (don't know the model #, but it was blue) was junk. Keep an eye out for the 10-20 % coupons from HF that show up on here from time to time as well to sweeten the deal.
      Pete
      • davidtu
        • 708
        • Seattle, WA
        Ryobi has one, but its $70 (online price, may be cheaper in store) and though I have one (came in kit) I have not had opportunity to use it yet... I will soon though as I will have to drive some lag bolts thru railroad ties to secure a small fence post. But, you could try their website ryobitools.com as they have a user forum there that appears pretty honest & unfiltered... but if you're here you probably know that already.
        Anyway, that is price w/o battery & charger... but if you happen to already have those items I guess you could consider it. I'm of course only responding to your query for others under $100 ... if the HF will do the trick seems a far better deal.
        Btw, I'm a newbie and one thing I've noticed with tools is that manufacturers assume you know what to use them for... as I said I got mine in a big combo kit... I think its good for my use of lag bolts (is it?) but what are you going to do w/ it? It'll give me maybe one more way to use it!
        I should mention that my HD is also having a Ryboi "special item" which is a Ryobi 18v Drill (better than in the combo, comes w/ levels on it) plus flashlight plus battery plus charger for $50--which I think is a pretty good deal if you needed a drill. I like mine ok and their power tools tend to get good bang-for-the-buck reviews.
        • Stormbringer
          • 1387
          • Floral Park, NY
          • Bosch 4000
          It's good for lag bolts (I just used my Ryobi Impact driver to do just that), it'll even take the lug nuts off your tires for ya although I don't suggest using it for this, but it's best use, without question, is to drive screws. You have a tremendous amount of control driving screws with an impact driver. Beats a drill with a clutch hands down IMHO
          Regards, Greg
          • jAngiel
            • Oct 2003
            • 561
            $35 is a good price but I don't know if it is for THAT one. I have heard mixed comments about it. I purchased the Ryobi 18v version for $29 (tool only, not battery) and it has been great. I much prefer it to the drill for driving and removing screws.
            James
            • AlanWS
              • 257
              • Shorewood, WI.
              Thanks all. I guess I'll give it a try next time I'm in the neighborhood of my local HF. With regard to its use, I plan on using it to drive screws. It's supposed to give a lot better control over how deep they go, and to be much better at preventing runout that can strip the head. I figure the HF one will let me try it. If it lasts for my likely light use, I'll have one. If it does not last, I'll get a better brand next time.
              There is a description of the way the impact direction prevents runout here:
              http://forums.taunton.com/fw-knots/m...s?msg=11918.10
              I think the direction of the impact (and the torque) are different for an impact wrench used for loosening up stuck nuts and bolts: it won't keep the bit in a screw head, so is not an appropriate substitute for an impact driver.
              edit: Drat, they don't have them in stock in my local store.
              Alan
              • TheRic
                • Jun 2004
                • 1912
                • West Central Ohio
                I have an impact driver (Ridgid 18V) I use it for about everything. It's the first thing I grap when I grab a drill. Putting screws in with an impact driver is 100 times better then a regular drill, even one with a clutch. The screw goes in much faster, but still gives you better control. I never would have thought it until I started using on.
                Ric
                • davidtu
                  • 708
                  • Seattle, WA
                  Based on the above recommendations, I used my Ryobi Impact Driver (first time!) to drive some 3" drywall nails through 2 2x4s and it performed great! The Ryobi clutched drill/driver could not handle it... it started stripping out the screws only 1/2 way in... I couldn't press any more firmly. The Impact Driver immediately drove that one home along with all the others w/ minimum of pressure.
