Costco has a Master Power by Cooper Tools portable air compressor for $134.95. It has twin tanks, 5 gallon total, is set for 120psi cut-in to 150 psi cut-off, has a stainless(or stainless look?) panel with 2 gauges, 2 air outlets and a pressure relief and puts out 6.8 scfm @ 40 psi and 5.6 psi @ 90 psi. It is an oiled design. If I hadn't bought a portable Eaton unit last month I would jump on this. Seems better built than the ordinary Chinese twin tank compressor, and the numbers are much better if they're real. It uses 15 amps.
Costco Compressor
