New Makita Two Base Router Kit $149 @ HDT
  • Stormbringer
    • 1387
    • Floral Park, NY
    • Bosch 4000
    Makita RF1101KIT2-HDT Variable Speed Router Kit Fixed & Plunge Bases
    ($200 at Amazon)
    (RF1101KIT2)
    Use Discount Code RF To See Final Low Price
    $149
    Motor:
    HERE's THE LINK
    http://www.heavydutytools.net/Scripts/prodView.asp?idproduct=312
    Powerful 11 AMP 2-1/4 H.P. Makita made motor
    Variable Speed Control Dial (8,000-24,000 RPM) to match the speed to the material being cut
    Electronic Speed Control circuitry monitors and maintains RPM under load
    Soft Start feature for smoother start-ups
    Quietest motor in its class
    Rugged aluminum motor housing with slender 3-1/4" diameter for easy handling
    Durable flat top design for stability when changing bits
    All ball bearing construction for long tool life
    Externally accessible carbon brushes
    Fixed Base:
    Industrial cam-lock for fast and easy depth adjustment and removal of motor
    Large calibrated depth control ring for easy depth adjustment
    Makita sub-base accepts industry standard template guides for convenience
    2 all wood handles
    Plunge Base:
    Conveniently located plunge lock lever for operator convenience
    Easy to use fine depth adjustment with 3 depth stops for consistent plunge cutting
    Nickel plated plunge poles prevent corrosion for longer tool life
    Maximum plunge depth of 2-19/32"
    Removable clear plastic shield protects the operator from airborne debris
