Sheets of 3/4" Maple Veneer Ply - $36
  • RmeDad
    • 231
    • Scottsdale, AZ
    New to WW, and I saw this locally. Need your help in determining if this is good enough quality to build some bathroom vanities and if the pricing is good?
    I emailed him to ask the grade, and this was his response to me:
    "They are B / C sheets, plain slice both side. B side can be used for outside pieces and the c may have pin knots but they are tight and smooth. I checked them out before I purchased them as I was building kitchens so they worked fine for my application."
    Any help sure would be appreciated. Thanks in advance.
    Jack
    Throughout my racing career I was constantly reminded of this: "Keep the pointy end forward and the shiny side up!"
    36$ a sheet for hardwood veneer plywood is pretty good, overall. BC is usuallly NOT good plywood. Most hardwood veneer ply is A/B faced. Are you painting your project?? Or wanted to clear coat or stain them? That'll make a difference. You can use veneers with knots and voids in the show face in painted projects so long as you fill the holes.
