Picture frame
  • rabmax
    • Apr 2015
    • 9
    • Henderson Nevada
    • BT 3000
    Picture frame
    I have an 8x10 inch mat that will hold a 5 x 7 photograph. I want to build a frame with a 1/4 rabbit. Is there a formula that will help me? Does the formula reference the outer or inboard measurements.
    Rabmax
    To fit your 8x10 mat, the inside dimensions of frame opening will be 7.5 inches by 9.5 inches, since you will rabbet in 1/4 inch on each inside edge. Is this what you're asking? If so, one formula for frame opening height might be: size of opening height = mat height - (rabbet width x 2). For width, substitute height in formula with width.
    If you're trying to figure out how long each uncut piece should measure on the outside of the frame - assuming you'll join the sides with a 45 degree miter cut - Add twice the width of each side piece to the length of the frame opening for that side. So a formula for outside frame height side length would be: length of frame height side piece = (mat height - (rabbet width x 2)) + (height side width x 2)
    So for your 8x10 mat, if using a frame piece width of 2 inches, with 1/4 inch rabbets -
    length of frame height piece = (10-(.25x2)) + (2x2) = 9.5 + 4 = 13.5
    length of frame width piece = (8-(.25x2)) + (2x2) = 7.5 + 4 = 11.5
    For a 5x7 mat with same frame piece width and rabbet dimensions:
    length of frame height piece = (7-(.25x2)) + (2x2) = 6.5 + 4 = 10.5
    length of frame width piece = (5-(.25x2)) + (2x2) = 4.5 + 4 = 8.5
    Last edited by Bill in Buena Park; 05-15-2015, 06:54 PM. Reason: added formula stuff
    • rabmax
      • Apr 2015
      • 9
      • Henderson Nevada
      • BT 3000
      Hi Bill:
      Thank you so much for your quick response, it certainly saved the day for me, and your info was spot on.
      Rabmax
