Ryobi 9 inch bandsaw
  • rabmax
    • Apr 2015
    • 9
    • Henderson Nevada
    • BT 3000
    Would a Ryobi 9 inch BS suitably cut a 1 3/4 inch block of poplar 5" high and 17" wide?
    The 1 3/4" dimension can be cut with this saw. the other two no. From Ryobi's website specs:
    Motor:^ 120V AC, 2.5 Amps SFM:^ 3,000 (no load speeds) Blade Length:^ 59 1/4" Throat Capacity:^ 9" Table Size:^ 11 3/4" x 14 3/4" Maximum Cutting Height:^ 3 1/2" Weight:^ 37.3 lbs.
    • Knottscott
      • 3815
      • Rochester, NY.
      • 2008 Shop Fox W1677
      It's not a tool I would run out and buy for this task. If you already have it, put on a sharp new blade with a low TPI count, and see how the 1-3/4" cut goes. 5" won't fit.
        Rabmax,
        If you're trying to resaw the poplar, it will only handle up to almost but not quite 4inches under the blade guide. If you get a 6tpi (or lower) blade for it, you can resaw, but with patience. The motor is a little underpowered for much resawing. It is fine for ripping stock around 2 inches, and good at curve cutting on 3/4 to 1inch stock.
        • rabmax
          • Apr 2015
          • 9
          • Henderson Nevada
          • BT 3000
          I thank you all very much for your responses. I do not generally us a band saw(nor do I usually do a 1 3/4 block) so I don't want to invest in a 14 incher but I have a $190.00 credit with Home Depot so I thought the Ryobi (or Rigid ) might be some thing to add to my collection.
          The last time I was on line it was still BT3, guess I am behind the time. I wanted to make a donation but it would not accept my money unless it was Paypal so I will work some more on that.
          I purchased my BT3000 in 98 or 99 and still have original shims and belts, my upgrades are still in the package. Guess I am lucky.
          Rabmax
            • 8791
            I didn't reply earlier as I wanted to see other replies. I have a Delta 9 inch BS and purchased it back in 2006 to make pen blanks - approximately 3/4 by 3/4 inch. I tightened, added some upgrade guides, adjusted and adjusted, but it did not do justice to 3/4 or 1 inch wood. Impossible to get real nice pen blanks 6 inches long.
            I couldn't get what I would say straight cuts no matter what I did. At the time I was still working in Japan and had a 12 inch band saw there and purchased the Delta for use back here. Small bandsaws rarely have the tension to cut thick wood in a decently straight line.
            • Knottscott
              • 3815
              • Rochester, NY.
              Rabmax
              Why not use your BT for the cut?
              • rabmax
                • Apr 2015
                • 9
                • Henderson Nevada
                • BT 3000
                It's for a bow front drawer.
