Motorcycle Cruise Control
    • 10481
    As most rider knows, the right hand and wrist get stiff or cramp up on long trips if you don't have a cruise control.
    Electra Glide Standard and Classic models without the factory cruise installed are built so it can be added with a prepackaged kit. Unfortunately the kit is no longer available for pre 2007 models. That left me to search the aftermarket offerings and I found several options.
    Wrist Paddles. These are simple devices that clip/clamp onto the end of the throttle allowing you to maintain control with the wrist so you can 'flex and relax your fingers. These are the least expensive but the right hand still has to be on the throttle and the wrist pressure on the paddle has to be steady.
    Throttle Locks. I found several brands of these. They mount to the throttle grip between it and the right switch/brake lever. Some are activated and released with buttons on the unit, others have a paddle to release the lock. The problem is in the name itself, throttle LOCK. In an emergency, if you don't have the time or presence of mind to hit the release, the brakes are going to be fighting the engine power.
    The one I found that looks safe is the BrakeAway. This throttle lock has a buttons to set and release the lock with the thumb for normal operation like many of the others on the market. The difference is that it also has a cam behind the brake lever that releases the lock when the front brake is applied without any other action by the rider. The drawback is that, at about $200, it is the most expensive option. In my mind, the safety factor makes it worth the extra $$$.
    http://www.brakeawayproducts.com/
    This is a photo tutorial on installation. The only thing I disagree with is in the last picture. Other comments I read said that, without a little space between the cam and the lever, the vibration of the brake lever can release the throttle lock.
    http://www.1300tourer.com/files/brakeaway.pdf
  • jaybee
    • 157
    • Regina, SK, Canada
    What is the cost of the nearest to your year kit? That is what determines the price of the brakeaway as high or low.
    • wardprobst
      • 681
      • Wichita Falls, TX, USA.
      • Craftsman 22811
      Don,
      I don't know about you but bike insurance runs that much for me every six months. Seems reasonable to buy the best here, you have a fine ride.
      DP
      www.wardprobst.com
      • durango dude
        • Mar 2011
        • 937
        My solution was to buy a BMW R1200 CLC.
        Love the double-take other bikes give when you wave with your right hand!
        No - I don't think I'd ever get a throttle lock. Seems like an invitation for problems.
        • Stytooner
          Roll Tide RIP Lee
          • 4301
          • Robertsdale, AL, USA.
          I personally wouldn't use it on a bike. I had a GF at one time that had a Harley 883 and I rode a Yamaha. It was a 650 Magnum with the drive shaft.
          I loved that bike. It did have a full fairing. When our wrists were cramping, it was time for a break anyway.
          I won't even use the cruise in my truck.
          I like having the illusion of control.
            • 10481
            I didn't check the price since it wouldn't work on my '02. Also didn't check the cost of all the individual components required. My cost comparison was only to the other aftermarket offerings.
            Originally posted by wardprobst
            Don,
            DP
            I have mine through GEICO and pay $241 for a 12 month policy.
              • 10481
              Most of them I feel the same about. The Harleys have a thumb screw under the hand grip that will tighten or lock the throttle. No way I would use that.
              Problem is that as I get older, the breaks would take up almost as much time as the riding.
