Ever cut into a piece of wood and find just a gem of a site? Here's one in some construction grade southern yellow pine. Like a thousand suns or a galaxy staring back at you.
Woodworking Inspiration!
I think in straight lines, but dream in curvesComment
You think so? I thought it was too small and too busy to bookmatch. But I do have a bandsaw now! The blade is crappy, but it should be a good learning experience. Thanks for thr idea.I think in straight lines, but dream in curvesComment
This reminds me of-Spirals and the Golden Ratio
From Movie "Pi"
"My new Hypothesis: If we're built from Spirals while living in a giant Spiral, then is it possible that everything we put our hands to is infused with the Spiral?"
-- Max Cohen in the motion picture
The Golden Spiral is a mystical shape that is an absolute in both abstract mathematics and chaotic nature. It was first discovered by Phythagoras, a failed Greek messiah and mathematical cult leader in the 5th century B.C.
The spiral is derived via the golden rectangle, a unique rectangle which has the golden ratio. When squared, it leaves a smaller rectangle behind, which has the same golden ratio as the previous rectangle. The squaring can continue indefinitely with the same result. No other rectangle has this trait.
When you connect a curve through the corners of these concentric rectangles, you have formed the golden spiral. The Phythagoreans loved this shape for they found it everywhere in nature: the Nautilus Shell, Ram's horns, milk in coffee, water going down the drain, Tornadoes, Waterspouts, Cyclones, Whirlpools, the face of a Sunflower, your fingerprints, our DNA, and the shape of the Milky Way.
Sorry, I stepped out of the box, the door slammed shut and I'm locked out.
Just some Brain Droppings.Comment
Cman - inlays, interesting thought, thanks again!
Annunaki, I am a fan of that website, I have scanned it a few times. The movie? Indy flick, I guess with limited engagement. Looks interesting. ThanksI think in straight lines, but dream in curvesComment
It's a beautiful piece of wood for woodworking--but definitely not the kind of knot i'd want in a structural piece of lumber. Escpecially not in the center of a rafter.
earlComment
Footer Ad
