Question - dowel jig
  • durango dude
    • Mar 2011
    • 937
    The DW picked up a dowel jig for me for Christmas (I'm happy!)
    Question, though ---- this jig (HF) -- is DROWNING in oil --- dark oil in fact.
    Doesn't quite seem normal.
    The jig is naturally stiff --- but it's also new.
    (wondering if someone put some automobile oil on it, then returned it).
    The S/H to/from HF is more than the jig --- - so a big fuss on my part won't be happening.
  • Dal300
    Banned
    • Aug 2011
    • 261
    • East Central Texas
    I would clean it off and see if it looks used and if it works.
    I've gotten a bunch of stuff from HF that was covered with unidentifiable substances. I think the Chinese are trying to help with the oil shortage by sending their extra over here.
    • unknown poster
      • 219
      HF steel tools are often coated in oil to keep them from rusting. Clean it off with a solvent. Carb cleaner works great.
      • phrog
        • Jul 2005
        • 1796
        • Chattanooga, TN, USA.
        I got one of the self-centering jigs for Christmas last year but took it back because the hole was not in the center. It, too, was covered in oil. Hope yours centers.
        Richard
        • durango dude
          • Mar 2011
          • 937
          quick note to HF brought a prompt reply (and a replacement)
          Hoping for improvement.
          Addendum ---
          Tried the "faulty" jig on a piece of scrap wood...... drilled some holes
          Hole 1: "__" Hole 2 (rotating jig 180 degs): "--:
          Conclusion - the auto-centering jig needs to be centered.
          I found the tuning nuts (you want to center the jig by adjusting the back-side threaded sleeve).
          After about an hour of dinging around ---- got the test holes within 1/64" of each other
          Bottom line - the Harbor Freight Jig should likely not be your first choice if you require precise dowel holes.
          • eezlock
            • 997
            • Charlotte,N.C.
            question about dowel jig
            The dowel jig is probably coated with cosomoline, to protect it from rust.
            It is pretty easy to remove with some spray carb cleaner from the auto parts store...just be sure to do the cleaning in a well ventilated area, fumes are kind of strong and you don't want to be breathing them in. eezlock
