an illusion
Its not much of an illusion to me, both mouth movements look different, and both sounds are different, the "V" doesn't sound like an "F". Maybe a different example would be better.
Pretty wild stuff for sure!Donate to my Tour de Cure
I think you missed the point. Yes, both mouth movements are different, however, the ACTUAL sound is the same both times. Yet, the sounds SEEM to be different, simply because the visual mouth movements are different.
If "both sounds are different" to you, then the illusion worked.JohnComment
problem is, moving the mouth different ways, the sound is actually different. it may be close, but still won't be identical. The only way they could do this with any true scientific merit would be to have the sound being made by something that isn't making the movement.
In other words record the sound and loop it, then have the video of a person making the two mouth movements in time with the recorded sound. Then it'd be convincing.Mike
Lakota's Dad
If at first you don't succeed, deny you were trying in the first place.Comment
I believe that is what they did. How else could they do the side by side video.
The entire point is about listening comprehension....right?
on the speakers I have on my laptop, I couldn't hear a difference at any point, but I knew what they were talking about. The method they were trying to use (through most of the segment at least) just didn't work for me.Mike
Lakota's Dad
