Need a new computer
  • Russianwolf
    • 3152
    • Martinsburg, WV, USA.
    • One of them there Toy saws
    Need a new computer
    Looking for a new computer, but want to play a new game and here are the minimum requirements.
    OS: Windows Vista/Window XP with SP2
    Processor: 3.2Ghz Vista/2.8Ghz XP
    RAM: 1.5GB Vista/1GB XP
    Video: DirectX 9.0C/10 compatible: NVIDIA GeForce 6800 GT256 or greater; ATI Radeon 9800 Pro (Radeon X800 Pro 256MB for Vista) or greater
    Now, I'm stupid when it comes to this stuff. Can I get something that will work for $300-$500 without the monitor (Lillian will want to be picky on the monitor)?
    The game is Mechwarrior Living Legends which is a mod based on Crysis Wars.
    Lakota's Dad
  • vaking
    • 1428
    • Montclair, NJ, USA.
    • Ryobi BT3100-1
    Specs seem outdated. Windows XP is around end of life. Vista was badly made and received from day one. Most new computers today come with Windows 7. Radeon 9800 Pro and GForce 6800 were high end video cards years back. Today they don't exist. How old is the game?
    Alex V
    • Russianwolf
      • 3152
      you are asking the wrong person. lol The mod is fairly recent, first came out in 2010 I think on Crysis, and now the current version is only on Crysis Wars.
      I know that Crysis 2 is available for Windows 7, but not the earlier version, I'm assuming its backwards compatible.
      (By the way, I love my Vista machine. Its had far fewer issues than my XP machines, and I've only had my work Windows 7 machine for a couple months and it has compatibility issues with nearly everything I have.)
      So my goal is a machine that's capable of playing this thing. Doesn't have to be able to play it at lightening speeds, but human reflex speeds. (I'm not getting younger)
      Lakota's Dad
        Mike, How do you feel about building your own? CompUSA, partnered with Tigerdirect, has some pretty decent barebones kits for good prices. I see a lot of really good deals in their email sales. Most anything new today will meet (and exceede) those minimum specs. You really want to exceede them. A lot of games will run at minimum, but a lot of the cool eye candy will have to be turned off.
        Don't get one with just onboard video if you want to do any gaming.
        I'm looking to upgrade my old Dual Athalon rig. It's getting really long in the tooth. I'll probably order a kit from them and add a SSD and Windows 7 Pro.
        • phrog
          • Jul 2005
          • 1796
          • Chattanooga, TN, USA.
          Win 7 Home Edition will not install about 90% of my programs (even using the compatibility wizard) which ran flawlessly on XP Sp2. On this forum I have learned that the Pro Ed will allow installation of some of those programs using the XP VM mode. But I haven't tried that yet. Just thought I would let you know that you may have issues with your older software if you spring for this OS.
          As far as the hardware you are looking for; I should think you shouldn't have a problem with the amount you are willing to spend. You might check newegg.com and tiger (as mentioned previously) for barebones systems. I bought most of my components from Amazon the last time I did a build from scratch - so you might check there if you are willing to put it together yourself. Biggest challenge will be finding a copy of XP to put on the system unless you decide to go with the newer Win7 OS.
          PS: Go with more RAM if possible - the more the better in most cases and that is not a lot of RAM for today's systems.
          Richard
            XP (32 bit) won't use more than 3gig. I've got a dual quadcore machine at work with 4gig, but when running XP it only sees three. Compatability issues kept us using XP.
              +++1 on the SSD. These things speed up a computer faster than a 3X processor. A few folks that I have interacted with have said the same thing. In general, the processor speed is seen as the power but the virtual memory that goes to and from the HD causes slow downs WAY beyond one could imagine - until an SSD is installed. An SSD gives a huge increase in speed, not incremental.
              • phrog
                • Jul 2005
                • 1796
                You're right about the XP limitation on RAM. I was actually looking at the spec he wrote of 1Gb of RAM. I would put a small amount more money now in more RAM if possible because 1 Gb in today's computers is very small. Thanks for pointing out the limitation.
                Richard
                • Kristofor
                  • 1331
                  • Twin Cities, MN
                  • Jet JTAS10 Cabinet Saw
                  Those specs are fairly lightweight, but those were the published specs for Crysis. You remember, the game when the video options were cranked up that brought the best multi-GPU rigs available at the time of release to their knees...
                  But, that video performance limited spec is also the best news for you...
                  The $1000 video cards of one generation tend to be only slightly faster (if that) than the midrange cards of the next generation, or the value cards 2-3 generations later. You're ~4-6 generations past those models of video cards (depending how you're counting) so even a cheap (<$100) video card should provide enough punch.
                  That means you have the flexibility to buy something in the lower end of your price range that will have plenty of CPU/RAM and add a video card if needed (make sure you have a x16 (physical) PCIe slot available on the new machine if you go that route).
                  As others have mentioned an SSD is a huge general performance boost, but specifically for games, video, CPU, and RAM will tend to be the bigger playability factors. Drive speed can determine load times, and in marginal systems may cause reads/writes and stuttering, but low frames/sec will be a more game-breaking symptom (for me at least).
                  • radhak
                    • 3061
                    • Miramar, FL
                    • Right Tilt 3HP Unisaw
                    Mike, you have very modest needs, and most of the desktop computers sold today will satisfy them, at minimal cost. To Kristofor's point, getting a better computer will only make for a better experience with that game or any other.
                    While building a computer is a great idea, it does demand a level of attention that many don't want to provide to acquiring a computer. But you can do almost as well with basic stuff sold. Eg : lots of systems advt on TigerDirect or Dell could give you that. And there are other great deals that keep coming up at various stores, even Staples, OfficeDepot, etc.
                    If you really want a built-to-order but not the hassle of assembling it yourself, you could try Directron; they have a $7 assembly service which includes testing the final system so you don't have to worry about a DOA unit. They have 'system specials', prices ranging from $200 and up that help you avoid having to think too much about what to buy. This $356 unit is a pretty good place to start , and you can always add the OS and other stuff you want. (I have not bought anything from them yet, because I need to get an approval from my finance secretary (LOML), but that's where I'm headed whenever : I have heard plenty good about them.)
                    While the recommendation for memory (4GB or more) is spot on, I daresay you could hold off on the SSD : you could do pretty okay with a regular hard-drive too if it has 7200 rpm. An SSD would be a quantum jump, but it costs a pretty penny too, and any new system would be a big jump for you as it is even with a regular SATA drive. You could upgrade to SSD a year or two later if you feel like it.
                    I do not want to downplay software compatibility issues with Win7, but if you are getting a new system, I strongly recommend you should upgrade. Once you are past the initial hiccups, you won't have to worry about the other stuff, like performance, support from MS for security patches, etc.
                    Edit : I just got an email from TigerDirect, and this Intel Core i5-2300 with 6GB, 1.5TB HDD, DVDRW and Windows 7 Home Premium 64-bit installed machine for $499 seems to be kickass at your price level.
                    - Aristotle
                    • crybdr
                      • Dec 2009
                      • 141
                      • Lake Mills, WI
                      I just replaced my old HP Pavillion a1320n (5-6 years old) with a new HP P7 1020. Currently $499 at OfficeDepot.
                      I thought about building my own - but had been looking around for some off the shelf computers for a while - and I pulled the trigger on this one. For me, HP has been good for a desktop.
                      As far as the P7 1020 goes - many gamers suggest a power supply upgrade when adding a new video card. I don't use the computer for gaming. I'm a pro-am photographer, and this machine is leaps and bounds above my old machine from a speed perspective. Also, the video playback is considerably better.
                      There are so many options out there. But I can personally recommend the P7 1020 based upon my experience so far. Not sure if it meets your requirements though.
                      Good luck.
