The thinnest, strongest material gets a Nobel Prize
  • radhak
    • 3061
    • Miramar, FL
    • Right Tilt 3HP Unisaw
    Physics Nobel Honors Work on Ultra-Thin Carbon
    Graphene ... is a single atom thick. It is not only the thinnest material in the world, but also the strongest: a sheet of it stretched over a coffee cup could support the weight of a truck bearing down on a pencil point.
    A funny way of specifying strength instead of PSI (i guess that's their 'layman' language), but that is intimidating strength : now I know what material is used for the costumes of all the JLA members (Superman, Batman, etc)...
    - Aristotle
    Being in the technician "caste" of science, I sure can empathize with that poor
    tech who showed them the Scotch tape method but will never bask in the
    glory of that Nobel because he's missing a few letters behind his name (PhD).
    Regardless. Big picture was never his but an honorable mention would have
    been nice.
    There's been so much made out of buckeyballs and nanotubes but nothing
    really has come to market yet. Hopefully something cool and revolutionary
    will come of this and it won't be better 3D TVs but something really game
    changing like a containment field for a super power cell.
    I wonder, though, why if a sheet of graphene is so strong that I keep
    breaking my pencils which is composed of many, many sheets of it.
    • All Thumbs
      • Oct 2009
      • 322
      • Penn Hills, PA
      • BT3K/Saw-Stop
      Well I hope before they start mass producing the stuff that they figure out a way to recycle it first.
      Otherwise we're going to have a bunch of indestructible stuff around.
      • woodturner
        • Jun 2008
        • 2049
        • Western Pennsylvania
        It was apparently the Ph.Ds that developed that method, according to the article and the research paper. Apparently not something a tech developed - the tech would be cited in that case.
        • cwithboat
          • Jan 2008
          • 614
          • 47deg54.3'N 122deg34.7'W
          • Craftsman Pro 21829
          or the bean stalk (aka space elevator)
          regards,
          Charlie
          Rudyard Kipling
          • natausch
            • Aug 2009
            • 436
            • Aurora, IL
            • BT3000 - 15A
            People made out of graphene houses should throw bricks, hammers and trucks.
            Although at one atom thick it is probably sharp as stinky cheese from the wrong angle.
            • woodturner
              • Jun 2008
              • 2049
              Kind of invokes Le Guin's molecular wire....
              • radhak
                • 3061
                • Miramar, FL
                Thinking this over a bit more, I am wondering how much of the report is hyperbole. Thickness of one atom is practically non-existent thickness - so a sheet of 'cloth' of this thickness should be transparent to the human eye. And then to be of the strength stated - that is borderline fantasy. Somehow it seems closer to description fit for a comic book than the nobel prize...
                wonder how they created and tested something like that; I'd dread to think this stayed at the level of theory.
                - Aristotle
                • woodturner
                  • Jun 2008
                  • 2049
                  Only if you look at the edge - if you look at it perpendicular to the face, it looks like any other sheet of material.
                  The details of the testing and production method are in the research paper. If you don't have access to research journals, your local college library should be able to give you access.
                  I found it interesting, no fantasy involved. Keep in mind work like this is peer reviewed before it is published and has been very thoroughly vetted by many, many people before even being nominated for a Nobel prize.
                    What's the big deal????? Publishers have been wraping bundles of magazines in stuff stronger than that for years.
                      Radhak, the sheet in question that was theoretically used to cover the coffee cup was not an atom thick, but the same thickness as a sheet of plastic used for wrapping a refrigerator. Check the article. I agree with you, one atom thick and you could easily displace one atom, and once that is done, I am sure more would give way. I think the really exciting part was the fact that the material behaves with different physics...classic physics don't apply for motion of electrons through the material. Instead they flow through it in waves at light speed!! I'm thinking quantum computing...
                      • luteman
                        • Dec 2007
                        • 145
                        • Northern Michigan
                        Wasn't the paper on Cold Fusion also peer reviewed?
                        • woodturner
                          • Jun 2008
                          • 2049
                          Actually, no. It was "announced" by the university but was not accepted for publication.
                          FWIW, some later concluded that they had discovered a previously unknown phenomena, it just wasn't cold fusion.
                          The wiki has a reasonably accurate historical account:
                          http://en.wikipedia.org/wiki/Cold_fusion
                          • billwmeyer
                            • 1868
                            • Weir, Ks, USA.
                            No, Ma Kent made Superman's costume from the baby blankets he was wrapped in on his rocket trip from Krypton. They were unraveled and cut by superman's heat vision.
                            I wish my mom hadn't thrown away all of my Superman comic books after I moved out.
                            • gsmittle
                              • 2793
                              • St. Louis, MO, USA.
                              Well, Bill, if you hadn't moved out you'd still have your comics.
                              I wonder if you can make a table saw blade out of graphene…
                              g.
                              Smit
                              "Be excellent to each other."
                              Bill & Ted
