How long can you keep plastic laminate rolled up? I scored some nice horizontal grade plastic laminate from a commercial shop selling 4x8 sheets for $15 a piece. Of course I snapped up 3 with no where to store them, but I thought it was a good deal. The stuff is pretty thick and stiff. Any ideas on detrimental effects of leaving it coiled for too long in a hot and humid garage??
Plastic laminate sheets?
I had two pieces of blue laminate, each 30" by 12' rolled to about 24" in diameter. Used the first and darn near lost a finger when I cut the twine on the roll. The second sat for a winter and spring and when the twine was cut it just sat there still rolled up. It was stored in an unheated space with temps down to below zero. I carefully unrolled it in the sun with some weight on it for several days and when the weight was removed it immediately rolled it's self up into about a 48" diameter roll. So I tried rolling it up the other way. In the mean time I bought another piece of laminate so that I could finish the project and forgot about the roll, left in the garage where it did get hot that summer. When I unrolled it the c enter part was reversed rolled and the ends wanted to roll the other way, I now had a roller coaster for hot wheel cars. When I glued it down I put another sheet of MDF on top and put weights on it and left it for a few days. It never really wanted to lay flat and after a year or so was puckered up in places.
The place where I bought it had it on a roll that was about 4" in diameter in the center they would spool off the length you wanted and after cutting it roll it in the other direction, when I asked was told to lay it flat as soon as possible and store it flat. I wished that I had asked when I bought the first two pieces.
So.... in answere to the question, Not Very Long!
over here in the fog, with a high today of about 60 deg. -
If you can't store flat, you can store them on edge. If you have a couple of 4x8 sheets of anything...plywood or melamine, etc, up against the wall, you can slip the mica in between.
.Comment
It worked out well, the pieces layed out pretty flat and I was able to make room to store them like Uncle C. mentioned. Thanks all. I did find a good reference for laminate info, really interesting to see what the industry was saying about using mdf instead of plywood and the reasoning behind the choice!
http://www.allbusiness.com/furniture.../599224-1.htmlI think in straight lines, but dream in curves
