Has anyone used one of these Chainsaw mills. I have a big old Maple that just fell over in the wind so I have a few logs that I would like to turn to lumber. So I was wondering if one of these was worth the money.
Chainsaw Saw mill??
I've not used that one, but I have used the bigger Alaskan two-motor mill and the $15 HF version.Has anyone used one of these Chainsaw mills. I have a big old Maple that just fell over in the wind so I have a few logs that I would like to turn to lumber. So I was wondering if one of these was worth the money.
The Alaskan worked OK, but it still doesn't work as well as band mill. The HF was good for rip sawing a log into manageable pieces I could get to the 18" shop bandsaw.
If you want to get usable 4/4 to 8/4 lunber, I would suggest trying to find someone with a band mill to cut the logs. If you have a decent size bandsaw, though, you may be able to use this type of mill to cut the logs into sizes you can wrangle onto the bandsaw.--------------------------------------------------
Electrical Engineer by day, Woodworker by night -
I have had three different size alaskan mills. They have their place and are as accurate as the person running them. About 500 to 1000 board feet a day is max when cutting 4 inch slabs. If you are under 40 and in good shape you might get a little more. They are a workout to run, but well worth the money.Has anyone used one of these Chainsaw mills. I have a big old Maple that just fell over in the wind so I have a few logs that I would like to turn to lumber. So I was wondering if one of these was worth the money.Comment
I have that mill but have never used it--moved shortly afterward to a home in town without any trees to cut down.
I did get a ripping chain, which is filed a little differently than standard chainsaw chains:
"I have used ripping chain on various setups. The chain indeed has a different angle for the cut tooth but every second tooth there is a raker tooth that is ground almost flat that cuts a path for the 10 degree teeth. The purpose of the ripping chain is to allow the saw to run with less power saving the saw. Also when using a chain saw mill the boards come off with no chain marks like a standard chain. As for costs the rip chains are the same price if not a couple bucks more. If you use a chain saw mill and want your saw to last and your cut to be clean with less planning afterwards you have to use a rip chain."
(from a logging forum)
I think it would suit your purposes if you just want to cut 1-2" boards from a small tree, <18" in diameter.
I might be willing to part with mine for $100 or so, chain included. If you're interested send me a PM.Jeff
“Doctors are men who prescribe medicines of which they know little, to cure diseases of which they know less, in human beings of whom they know nothing”--VoltaireComment
Footer Ad
