I think I goofed
That is a very clever photoshop job. I am calling it that rather than it being taper cut that way because the grain pattern doesn't look right.David
The chief cause of failure in this life is giving up what you want most for what you want at the moment. -
You must be working on an Escher piece...Jeff
“Doctors are men who prescribe medicines of which they know little, to cure diseases of which they know less, in human beings of whom they know nothing”--VoltaireComment
Green Gables: A Contemplative Companion to Fujino TownshipComment
It is an Escher thing. in the forground the 2 pieces of wood are one on top of the other & the back ground they are next to each other. the foreground right of the top pieces becomes the top of the other pieces in the back ground. The only way that could happen is if there is only one piece of wood, but the end grain indicates that 2 pieces were used to compose the picture.Comment
