Finding part # for Dodge Caravan seat screws?
    Our 2000 Dodge Caravan has some missing screws that hold the trim pieces on the sides. I've removed one of the screws that is still present and it cranks down fine in the holes that are missing screws, so I'd like to just get some replacement screws.
    Is there a place (online) where I can find a part # for something like this?
    Yes, I could go to the hardware store and perhaps find something close. But if they aren't too expensive I'd just as soon order some OEM screws.
    It is a black oxide part with a Phillips head and a built-in washer.
    From your description, those sound like typical trim screws, that you can buy either in the help section of the autoparts stores (prepacked common stuff), or from most autobody parts places.
    If you would prefer online, Rock Auto seems to be the prefered vendor in several sites I visit.
    • TCOTTLE
      • May 2009
      • 152
      • Greenbush Maine
      I'll see if I can get you the number, i work at a dealership. (Well, 17 dealerships technically.)
        If TCOTTLE can't find the part # I'll look into that.
          Hey thanks!
          17 dealerships? That actually sounds kinds fun.
            Quite often CG.. a part as such will come up N/A on a factory parts list. The N/A is not available and doesn't mean it was dis-continued but.. simply it is a standard type screw or nut that can be purchased readily through many sources and the OEM source is not going to bother to stock.
            If TCottle does come up with a number.. it will probably cost you several $ for a screw which you can find at any source that carries supplies for auto body shops and trim. If you have a local independent auto upholster.. drop by and likely they would sell you one cheap as it probably cost no more than $.20 each through one of those sources.
            Good luck...
