Sure, but locking your brakes on a car doesn't help you stop, it just ruins your tires and leaves black marks on the road. In normal cases the ability of the brakes to stop the wheels from spinning is not the limiting factor in how quickly the vehicle will stop. That's determined by the amount of friction at the tire/surface interface.
A car with a stuck accelerator pedal however is one of the non-normal cases. In this case you would need to know how much surplus force the engine can generate after accounting for wind resistance/drag and the various internal/rolling friction losses. If that quantity is greater than the force the brakes can apply to the wheels the car will accelerate, otherwise it will slow down.
I'm guessing that Jim is right and most street vehicles have more braking power while moving than engine power but I've never tested it on my cars, and in any case Loring is right when answering the OP that ABS doesn't come into the equation....
is that the brakes would let up until the wheel started accelerating again (due to the floored gas pedal or to regaining traction), and then be reapplied until it starts slowing down again. I think this would be just a matter of milliseconds, though, so I can't imagine it would have that big of an impact on braking distance.
