%#@*&% Shredder
    %#@*&% Shredder
    LOML bought a new shredder before I could try to fix the old one. The old one isn't that old, but didn't get the job done. She tells me to throw it out. Well, since I'm somewhat mechanically inclined, I can't see throwing out something if I can fix it.
    It seems she was oiling the shafts of the cutters, and paper shards were all impacted in the movement causing a drag. So, I attempted to dismantle the head, and it looks like after 30 minutes it may take a while. Maybe I can clean everything out...maybe not. If this bit of maintenance will make it functional again my time spent may worth the effort.
    So, is there a deduction to be made with making the decision of trying to fix it, or just pitching it?
    Pitch it, or at least get rid of it. Ever heard of freecycle? It will be worth it to someone to take it and try to clean it out. Although it all comes down to whether you think your time is worth it to fix the old one.
      I was thinking of fixing it for a back-up. When it worked it was pretty good.
      • alpha
        • 352
        • Owensboro, KY, USA.
        I agree with David's first two sentences.
        I disagree with David's last sentence because of what you said in your third sentence. Just do what she said and you'll keep peace in the home.
          If I fix it I'll be a hero, and my hubby points go up.
          • radhak
            • 3061
            • Miramar, FL
            • Right Tilt 3HP Unisaw
            My personal experience has been that shredders, particularly the ones made for at-home use are designed poorly. It's easy to jam them, and once jammed, many-a-times they sorta hobble that point on. You seem to have had better luck than me, but it had to run out ...
            I've finally given up on my latest home unit, but am unable to throw it out, because SWMBO doesnt' like the idea of "throwing something out before it provides its money's worth"...try figuring that out..!
            - Aristotle
              That's exactly my thoughts. If the motor went paflooey...then I would just trash it. Even then, I would cut off the cord and save it.
              • phi1l
                • Oct 2009
                • 681
                • Madison, WI
                I would give cleaning it out a try..
                there's only 3 things that can go bad with those.
                1) The motor could burn up..
                2) The blades get dull
                3) it gets gunked up by someone putting too much oil on the thing, due to 2 above.
                SO I would clean the c*** out of the blades. If the condition recurs, Dismantle it & use the motor in your next stroke of genius invention.
                I love freecycle, I just picked up a $500 mountain bike that just needed need tires. But I hate it when people try to foist off stuff that doesn't work & can't be economically repaired ( "Inkjet printer with issues it's out on the porch in the rain. First one here gets it")
                • Alex Franke
                  • Feb 2007
                  • 2641
                  • Chapel Hill, NC
                  Mine went out a while ago, too. I took it apart with my son and we found a blown fuse (totally inaccessible and soldered onto the circuit board). Out came the soldering iron, and it was an easy fix. Plus my boy learned a bit about electronics and fuses that day
                  In any case, I always try fixing things before I just toss them.
                  • billwmeyer
                    • 1868
                    • Weir, Ks, USA.
                    I enjoy fixing things. So I would take it apart, do what ever you can, and then when it won't go back together pronounce it dead and get another one! At least that how it usually works out for me. Once it is apart, the problem is usually solved.
                    • phi1l
                      • Oct 2009
                      • 681
                      • Madison, WI
                      .. one way or the other
                        LOL, who's on first?
                        • billwmeyer
                          • 1868
                          • Weir, Ks, USA.
                          Exactly!
                            Absolutely. Paper was packed in tight around the shaft and the fixed ends. Once I got it all pulled out, it works like a champ. The HF set of dental picks worked great.
                            • jabe
                              • 577
                              • Hilo, Hawaii
                              I had a shredder that clogged often cause the fins that were suppose to clear the blades from clogging were made of plastic and were broken. I got tired of taking it apart too clear it so I just trashed it and bought a HD shredder from Amazon $200. w/free shipping. You can not put a price on protecting your identity.
