Cargo Carrier Recommendations Needed
  • toolbelt diva
    • Oct 2004
    • 202
    • Houston, TX, USA.
    • Ryobi BT3100-1
    Does anyone have either of these cargo carriers from HF and would you recommend either? Or would you recommend one from someplace else?
    http://www.harborfreightusa.com/usa/...o?itemid=92655
    http://www.harborfreightusa.com/usa/...o?itemid=34313
    Rita
    For some reason your links don't work. Here are some that do:
    http://www.harborfreight.com/cpi/cta...emnumber=92655
    http://www.harborfreight.com/cpi/cta...emnumber=34313
    I've no experience with either but I would go for the aluminum one. It won't rust and it will be a lot lighter for the same weight carrying capacity. It also has higher sides.
    • sweensdv
      • 2872
      • WI
      • Baileigh TS-1040P-50
      I've got the 92655 and would recommend it highly. Very well built and being that it's aluminum its lightweight and very easy to mount. It does go on sale on a fairly regular basis so I wouldn't pay the full $80 price for it.
      • toolbelt diva
        • Oct 2004
        • 202
        • Houston, TX, USA.
        • Ryobi BT3100-1
        Thank you so much for the recommendations. Someone posted a $59.99 coupon for the aluminum one in the Bargain Alerts section, so based on your recommendations and the sale price we'll be getting that one.
        Rita
          Advantages to the aluminum are 1/2 the weight, rust proof, and rails on all for sides. I would go that route unless you need the open ends or extra 11" of length for what you will normally carry.
