DCX File Problem
    DCX File Problem
    Having a bad time trying to open a DCX file (email). Is there a trick?
    It looks like there are several programs that use files with a dcx extension.
    Is this supposed to be a raster image? (photo, scan, fax)
      It's supposed to be just a document.
        Hmm, might try saving the file to your harddrive and renaming the extension to .docx
        • RayintheUK
          • 1792
          The DCX file extension is sometimes used to transmit multi-page faxes. If this is what you think this attachment is, then download a copy of the excellent (and FREE) IrfanView. HTH
          Ray
          Did I offend you? Click here.
            Thanks for the suggestions. I've tried saving it to the HD and can't get anything to open it. A window tries to configure Acrobat 7 and fails. I'm sure it's all text, and tried Word, but error says the file wasn't coded (from email).
