I have about 50-60 old slides I need to scan. Can anyone recommend a good and reasonably priced slide scanning service?
Advice on scanning slides?
"Life is short, Art long, Occasion sudden and dangerous, Experience deceitful, and Judgment difficult." -HippocratesTags: None -
Ah-HA! I found the ONE question that nobody here can answer!
Here's just an update in case others search and find this thread. More slides came along -- about 250 total. I found and priced out several services, including several from the list below. But in the end I ended up just buying an inexpensive, but highly rated slide/film scanner. This way I don't have to send the slides anywhere, and I can scan any more that come along -- even at a higher optical resolution than many of the services, if that's what I want to do.
I bought a Canon CanoScan 8800F for about $160. That should do the trick.
Here are some of the services I found:
https://www.slidescanning.com/
http://www.scancafe.com/
http://www.digmypics.com/
http://britepix.com/slide-scanning/
http://www.digitalpickle.com/
http://www.scantodigital.com/
http://www.slidestodigital.com/
http://www.fotobridge.comonline at http://www.theFrankes.com
"Life is short, Art long, Occasion sudden and dangerous, Experience deceitful, and Judgment difficult." -Hippocrates -
I was going to suggest a slide scanner (I have a NIkon) until you mentioned you only needed to do a small number; I didn't think it'd be worth it for that; I hope the Canon works out for you. If you're into photography projects, there are also DIY ways to copy using a digital camera with slide holder and macro lens. You can see one setup HERE.. See also this page.
Edit: Link fixed, I hope.Last edited by Norm in Fujino; 10-10-2009, 09:52 PM.==========
Green Gables: A Contemplative Companion to Fujino TownshipComment
Thanks, Norm! Yeah, I didn't think it was worth it for only a few slides, either. But then a few more boxes turned up and suddenly it because a question of time or technology.I was going to suggest a slide scanner (I have a NIkon) until you mentioned you only needed to do a small number; I didn't think it'd be worth it for that; I hope the Canon works out for you. If you're into photography projects, there are also DIY ways to copy using a digital camera do it, using a slide holder and a macro lens. You can see one setup HERE.. See also this page.
That camera idea is interesting, but it seems like overkill for me. The first link didn't work for my, btw.online at http://www.theFrankes.com
"Life is short, Art long, Occasion sudden and dangerous, Experience deceitful, and Judgment difficult." -HippocratesComment
Sorry, I think I fixed the link now.==========
I purchased about a week ago an Epson V500 for scanning slides as well as old negatives. It is a slow process, four at a time, but as I learn more about the proper operation of the scanner, I think that I am going to be pleased with the Epson.SOW YOUR WILD OATS ON SATURDAY NIGHT - - - THEN ON SUNDAY PRAY FOR CROP FAILURE!Comment
Cool -- we should compare notes. It seems like there's been a big debate raging lately over which of these two scanners is better.
It looked like a toss-up to me. I chose the Canon because I've had a lot of success with other Canon products and because it had more reviews on newegg and Amazon -- I figured maybe it was more popular.
But we'll see... I expect we'll both be happy with the results.online at http://www.theFrankes.com
For some reason, I didn't see the original post. Sorry about that. I expect you'll be happy with the results you'll get with either of the scanners mentioned.
EdDo you know about kickback? Ray has a good writeup here... https://www.sawdustzone.org/articles...mare-explained
For a kickback demonstration video http://www.metacafe.com/watch/910584...demonstration/Comment
