HELP -New Table Saw
  • lebomike
    • Jan 2008
    • 146
    • Pennsylvania
    HELP -New Table Saw
    I have looked at the Grizzley G0478 Hybrid and now I am looking at the Ridgid with the granite top. Any comments on these two saws appreciated. Good bad or indifferent.
    Thanks
    "The power of kindness is immense. It is nothing less, really, than the power to change the world."
  • Knottscott
    • 3815
    • Rochester, NY.
    • 2008 Shop Fox W1677
    Both have their fans, but the G0478 has a more proven track record. The R4511 has undergone an arbor recall, and many question the fence. The Grizzly fence is pretty nice, but of course the saw is quite a bit more money. I'd definitely be more comfortable going with the Griz, but I'd be uncomfortable shelling out $944 for a hybrid, when I could get a G1023SL for $1075 to my door.
    If you don't have 220v, then the Griz is a good choice, but I'd also investigate the G0661, Craftsman 22124, and the Jet Proshop.
    G0478
    G1023SL
    • Mrk67mark
      • Aug 2006
      • 63
      • Ocean Springs, MS
      • Grizzly G0478 hybrid
      I have the G0478 and I love it. I would highly recommend it. I'm just a hobbyist, but I have yet to bog it down. I've run 6/4 oak and walnut through it and it cuts all without a problem. I do not have 220 in my garage, which is one of the reasons I went with the Grizzly. Dust collection is good, the fence is outstanding. Miter gauge is like most stock miter gauges, just OK. The blade guard is a piece of junk. I don't use it, but do use a splitter in my homemade ZCTP's. The blade changing wrench bent the first time I tried to remove the blade, so it ended up in the trash. Overall, I am extremely happy with my saw.
      Mark
      • Charlie
        Banned
        • Jul 2009
        • 210
        Deleted by me.
        • lebomike
          • Jan 2008
          • 146
          • Pennsylvania
          Was on the road yesterday , so checked some of the saws recomended today and am leaning toward the Grizzly G0661. The one advantage I have is the Grizzly plant is only one hour from me, so no freight and am able to go look at all the models. I am going to head up that way Monday and check them out.
          The one thing I think about is the weight of these saws, they have a forklift to put the saw on my truck. However when I get back home got to get it off the truck and in the shop/garage. Will have to check with neighbor to see if he will help take it off.
          Thanks for the input, will let you know what I purchase.
            If you have to take it off yourself, you could use cribbing. I moved a several hundred lb woodstove myself down a 2' drop twice this way. I used 2x4s stacked as cribbing. I would pick up one side of the saw and put cribbing in until it was as high as I needed it then push it onto the patio. When I was ready to refinish it and install it I stacked up the cribbing, pushed it on, then started taking pieces out until it was lowered.
