The chimney cap blew off in the big wind. Looking at it, it looks like friction fit as there is no evidence of screws or a collar.
There is a metal sheet that sits on top of the chimney with a collar that extends down into the bricks. This part seems to be glued in place. The pipe comes up flush with this collar and there is a thin gap between the collar and the outside of the pipe. I assume the cap is supposed to fit in this gap, but it is sitting up there now and there is absolutely no friction. It is not as tight as it could be, since the flange that meets up with the sheet on the chimney is a little warped from the fall.
I did not want to bang it around too much until I had some clue what I was doing.
