Comcast/detested neighbor rant (long)
  • cwithboat
    • Jan 2008
    • 614
    • 47deg54.3'N 122deg34.7'W
    • Craftsman Pro 21829
    Last fall my new neighbor to the south is building his house and needs to run conduit across my driveway to his place. Naturally he breaks the water line with his backhoe. The break is repaired and after calling Comcast several times to install their cable without results, the trench is filled in with gravel. The neighbor is going to put in a concrete driveway for me when he does his so the asphalt is not replaced.
    Six months later, in the spring, a guy from Comcast comes to my place and wants to dig up my driveway for his cable. After arguing with them for a while the guy says he has a utility right of way and he is going to put his cable in. So he digs up the trench puts in 2" plastic pipe and fills the trench back up and leaves.
    This summer we have a record setting heat wave. The universally detested neighbor to the north built his house six years ago and stuck his heat pump on the south side of his house right out side our bedroom window. Lacking air conditioning we would have liked to have had the window open for cooling, but the heat pump is running and making a horrible racket. As this is the neighbor from **** (actually the guy is alright his wife is a shrew), we decide to bite the bullet and have a fence installed.
    Yesterday the fence guy comes to install the fence and he notices that the ground is soggy neat the driveway and that the northern neighbor has a hose running into mole holes directly above my property line. We open the water meter box and its full of water. We call the PUD and he digs around the meter box and reveals a leak in the repair that was done last fall. The Comcast pipe is resting on top of rhe repaired section.
    So, I surmise, that the mole flooding subsided the ground allowing the Comcast pipe to press down on the repaired section causing the leak.
    I am writing this as I wait for Comcast to come and fix this mess. I am wondering if I will have to wait for six months.
    regards,
    Charlie
    Rudyard Kipling
  • BobSch
    • 4385
    Sorry to hear about all your problems.
    Sounds like Comcast is as bad in your neck of the woods as it is here.
    Bob
    • catta12
      • Jan 2008
      • 250
      • Reno, NV
      • BTS20R
      My in-laws just had a fight with Comcast too. They just needed Comcast to connect the cable back up for service. Comcast service had been in the house before, but it was suspended for some time when the previous owners switched to satelite. All of the Comcast lines were still intact.
      The Comcast tech that came out when they were not at home (they were going to call before they came out) and dug a trench through their front yard of newly planted grass.
      My in-laws were ecstatic about this. Comcast seems to have the same level of service everywhere.
      If you can read this you assembled wrong.
      Alan
      • RAV2
        • Aug 2007
        • 233
        • Massachusetts
        • 21829
        So much for the commercials that Comcast is running that acuse Verizon of digging up your yard to install FIOS.
        Just waiting for the newspaper article stating that Verizon has a court injunction to stop the misleading commercials.
        • cwithboat
          • Jan 2008
          • 614
          I am still waiting for them to show up. Fortunately there was a plumber nearby. We will bill Comcast.
          regards,
          Charlie
          Rudyard Kipling
          • cwithboat
            • Jan 2008
            • 614
            Comcast arrived yesterday afternoon. It only took them 4 days to get here. Contrast that with the P.U.D. (a government institution) who got here in 45 minutes.
            regards,
            Charlie
            Rudyard Kipling
            • Hoover
              • 1273
              • USA.
              I don't know how Comcast stays in business. Nobody seems to like them at all. They offer a teaser rate, in order to get their foot in the door. Then after that the truth comes out.
              No good deed goes unpunished
              • just started
                • Mar 2008
                • 642
                • suburban Philly
                They ALL do that, and just try to find out what the real rate will be after the give-away intro and you will need a triple-extra-large steam shovel running at warp speed to keep your head in the clear.
