Hoists (Again)
  • jackellis
    • 2638
    • Tahoe City, CA, USA.
    Hoists (Again)
    The new house is almost finished (pics soon). I have moved some partially finished cabinets and dust collector parts into the shop (with the builder's permission) and I will be using it for a finish room (brush or wipe, no spraying) today.
    In the process of moving some relatively light items down the side slope and across the gravel in the back (required for drainage), I confirmed that moving my heavy tools along the same path will be very difficult and dangerous, which is why we added rear double doors to the shop and the garage in the first place.
    I've looked at electric hoists and this site has what appear to be typical models from several manufacturers that would be suitable.
    I need an outdoor-type hoist that will stand up to 6 months of snow and repeated freeze-thaw cycles per year, plus direct, severe UV exposure all year round (6400' elevation). I do not want to have to get on a 30' ladder to put it the hoist up and take it down - no sense risking damage to the house when I fall off the ladder with the hoist in my hand.
    The biggest load I would put on this thing is my table saw, which had a shipping weight of 440 pounds including packaging and a router lift. The jointer and bandsaw weigh less, though I suppose I could be in the market for bigger tools some day. I don't know whether the advertised loads are safe working loads or whether safe working loads are a fraction of the advertised load but I'm thinking a 1000 pound load and 20 feet of lift (distance from ground to top floor landing) will suffice. However, the ridge beam is about 32 feet above ground level. That might require a longer lift.
    At this stage, I'm trying to figure out what questions to ask the suppliers. With moving day approaching fast, I might also just tell the movers what conditions they can expect if they attempt to move tools around the outside of the house (they absolutely cannot bring them through the house!) and suggest they might want to rent a suitable portable hoist system that can lower tools from the back door of the garage.
    I still want the hoist for firewood and sheet goods, but neither is critical at this point.
    I know it's been discussed before, but is there no way to mount the hoist on an I-beam, enabling it to be drawn inside? This would solve the weather problem and also make it a lot easier to deal with a >400lb. tool.
    • jackellis
      • 2638
      In this case, no. The top floor contains a large room that's for my wife's toys. The middle floor contains the garage. Shop is on the bottom. There's no attic. The hoist mount will be positioned on the ridge beam so that it is directly above the middle of the hoist platform - probably 2 feet from the side of the house.
      • bruce hylton
        • Dec 2008
        • 211
        • winlock, wa
        • Dewalt today
        Bury an axle housing in concrete in front, stand a long schedule 80 steel tube with an 'L' arm at the top made from 4" "H" beam six to eight feet long as needed. Add an electric hoist from HF that will roll length of "H" beam. Use plastic cover when not in use. Axle will give you swing action and mutiply use a 100 time over.
        • sscherin
          • 772
          • Kennewick, WA, USA.
          My thought was a ground level mounted cable hoist and a pulley at the ridge beam.
          Then you could build a weatherproof enclosure for the hoist.
          Hanging a pulley block will be much safer than hanging a big heavy hoist too
          William's Law--
            That was my thought too - pully up top and hoist on the ground. Much safer and much easier to service if needed.
            • jackellis
              • 2638
              Sounds like a pulley system might be the perfect solution if I can find a way to keep the wire rope away from a third floor window when the hoist system isn't in use. I'll have to take a look here shortly and also take a photo or two.
              So much for my expensive college education
              • Tom Miller
                • 2507
                • Twin Cities, MN
                How about a pulley on top, like others suggest, then a pulley anchored at the bottom also, where the cable makes a 90 degree turn into the shop (through a small hole) where the hoist is out of the weather?
                Just trying to think outside the bun.
                Regards,
                • Mr__Bill
                  • 2096
                  • Tacoma, WA
                  Just remember with a pulley at the top you put twice the weight on the ridge beam. Your 400 lb table saw will put 800+ lb of weight on the beam.
                  I like the pulley idea you could put the pulley at the top and a shiv at the garage level and attach the end of the cable to the trailer hitch on the truck..... you would find out just how much your wife loves you and the shop
                  The other way is with an ATV with a trailer.
                    How? If I wrap a cable around the saw, pick it up and suspend it from a hook on that beam, then there is 400lbs hanging from the beam. If I pick up the saw again and have you run the cable through a pulley instead of the hook there is still 400lbs hanging from the beam.
                    • cwithboat
                      • Jan 2008
                      • 614
                      • 47deg54.3'N 122deg34.7'W
                      • Craftsman Pro 21829
                      I guess I came in late. How do you get 6400 ft of elevation in Los Altos?
                      regards,
                      Charlie
                      Rudyard Kipling
                        Actually thinking about it I think I might have it... if the cable runs through the pulley and I am holding the end of it, then the weight is pulling down with 400lbs of force and I also have to pull down with 400lbs of force to keep it from falling. Therefore, there is an apparent 800lbs total load on the beam.
                        • jackellis
                          • 2638
                          In a month I'll be changing that address to Tahoe City, California. Our home plus the new shop will be about 200 feet above lake level.
                          Tomorrow I'll post a photo or two of the rear of the house.
                          • just started
                            • Mar 2008
                            • 642
                            • suburban Philly
                            You could use one of the new radio controlled winches made for bumper mounting. That will take care of the control cable problem AND the outdoor mounting, they are made to stand up to living on the front bumper of a vehicle.
                            • Wood_workur
                              • 1914
                              • Ohio
                              • Ryobi bt3100-1
                              But they are also deigned for lateral pulling, not vertical pulling.
                              Correct. But if he is mainly using it for sheet goods and firewood, then how much weight is it really gonna have to support? As long as it can handle the 800 lbs for the table saw (which will be less than 800 lbs when you are lowering it) I think it will be more than enough for what else he plans to do with it. And if he needs to he can put it closer to the house to lower the saw and have someone hold the saw away form the house as it is being lowered.
                              Alex
