An Engineering Kernoodler
    Today I planned to set the ridge beam for the shop. 2x8, 24' long and set approx 40" above the 8' walls. Before I put the center poles up I screwed plywood gussets to the faces so that when I did get the beam up, it would slot in between the gussets. Anyhoo, my plan was to crib up each end using my ladders then slot it into place. I had to overcome when it was on an angle being shorter and one end wanting to fall back into the shop. I also had to overcome it wanting to tip sideways. After trying various things to lift it for a while and it falling and grazing my shoulder, I decided pride wenteth after the fall and called my dad. He came over, looked at it and suggested something that would have enabled me to do it myself. The something overcame both problems and the beam is set. So the kernoodler is, what was his suggestion? It was amazingly simple and I should have thought of it.
    Oh, for full disclosure the last thing I tried was to make two lift sticks - 2x4s with short blocks nailed to each face to make cradles for the beam to sit in. However, once those got off the floor they were too unsteady and the whole thing wanted to (and did) fall over.
  • TB Roye
    • 2969
    • Sacramento, CA, USA.
    I will bite. what is a Kernoodler?
    • Bill Stock
      • 186
      • Canada, Eh!
      I'm sure it was something else but I probably would have (tried) pulled it up with a couple of ropes.
        Puzzle, conundrum, perplexer, brain exerciser, etc. I guess a kernoodler is a regional word or something. And no, what a kernoodler is, isn't the kernoodler.
        Bill, I thought about ropes but figured by the time I framed up something to tie the ropes to, my dad would be over helping me.
        • thestinker
          • Oct 2005
          • 613
          • Fort Worth, TX, USA.
          I'll take a guess....a pick up load of day labors
            Nope. Although one did help when we took the shop down and I gotta say he earned every bit of his money.
            Ok a hint. We used 2x4s.
            • sparkeyjames
              • 1087
              • Redford MI.
              Ok I'll take a stab in the dark at it.
              4 long 2x4's 2 for each end of the beam in a scissor fashion?
              This thread will need picture proof when all is said and done.
                We have some smart members here. Yeah - basically an a-frame. It solved two problems - one being when lifting one end up to get it set, the other would want to fall off the top of the wall. The other problem it solved was the beam wanted to tip over and the legs of the frame acted as a counter balance.
                I will get pics tomorrow, I promise. The last couple weekends by the time I think about pictures I am scrambling to get the tarp on.
                • gjat
                  • 686
                  • Valrico (Tampa), Florida.
                  I would have used a few 2x4's as a pivot jack to get one end up by myself and lashed the raised end to keep it in place, or nailed a block on the floor to keep it there, depending on how much play was in the gusset slot. The other end I would have lifted up with a rope from a ladder.
                  • TB Roye
                    • 2969
                    Now I understand. "Swedish Ingenuity".
