Pressure Washer has Prostate issues
  • Bill Stock
    • 186
    • Canada, Eh!
    You pull the trigger it dribbles, evetually a small stream will form and finally thar she blows. Is this some kind of valve issue?
    PW is a Karcher with Hoda 6.5 engine. Engine runs OK, no apparent leaks and I don't see any hose kinks.
    TIA
  • conwaygolfer
    • Jun 2008
    • 371
    • Conway, SC.
    Mine does the same thing. It first has to get the air out of the line and then it builds pressure. Once the air is gone, it is fine.
    Glenn
    • Hellrazor
      • 2091
      • Abyss, PA
      • Ridgid R4512
      It ate baked beans and has gas?
      Here is what you need to do. Hook up the hose, turn the water on and pull the trigger until water goes through. Now you should be able to start it and use it without the air problems. This worked on my deceased no-name and my Husky pressure washer.
        Glenn
        Mine too. Typical, I guess.
        • Bill Stock
          • 186
          • Canada, Eh!
          Glenn
          Thanks, I get the air thing. But it does it EVERY time I stop.
          • Tom Slick
            • 2913
            • Paso Robles, Calif, USA.
            • sears BT3 clone
            could be a sticky bypass valve or BPH. does it have to go frequently? get up in the middle of the night? oops that was a Avodart commercial, not pressure washer troubleshooting.
            seriously, it is probably a sticking bypass valve.
            • Bill Stock
              • 186
              • Canada, Eh!
              Can this be serviced or is it a straight replacement? Will Saw Palmetto work?
              • Tom Slick
                • 2913
                • sears BT3 clone
                I'd suppose it depends on the pressure washer itself. You'd have to take 1000 saw palmetto pills to get the power of just one of our capsules As always you should consult your health care professional before starting any new medications or supplements.
                • gsmittle
                  • 2793
                  • St. Louis, MO, USA.
                  I think it's time to call Bob the Enzyte Guy…
                  g.
                  Smit
                  "Be excellent to each other."
                  Bill & Ted
                  • Sam Conder
                    Woodworker Once More
                    • 2502
                    • Midway, KY
                    • Delta 36-725T2
                    Here in KY we have a to deal with lots of hard minerals in our water that deposits on/in EVERYTHING that requires water. We have a lot of limestone bedrock that is the source of our troubles. It's all worth it though IMHO, because our water tastes the best of any tap I've ever had.
                    If it happened to me, my first inclanation would be to run a heavy dose of vinegar through it. Kinda disgusting to think about, but sort of a "douche" for your pressure washer.
                    YMMV.
                    Sam Conder
                    BT3Central's First Member
                    • scmhogg
                      • 1839
                      • Simi Valley, CA, USA.
                      Bill,
                      Karcher makes maintenance kits for their PW's.
                      Steve
                      • ragswl4
                        • 1559
                        • Winchester, Ca
                        • C-Man 22114
                        Outside chance you might have a leak somewhere that lets air in when you turn it off. My Husky does the same thing when I first turn it on but now I run water through it before I power it up (as suggested by another poster) and that eliminates all the air.
                        RAGS
                        Raggy and Me in San Felipe
                        sigpic
                        • Bill Stock
                          • 186
                          • Canada, Eh!
                          YMMV.
                          Thanks, I did read this somewhere else. It does seem better today, I guess the usage is cleaning it's pipes.
                          Question though, is there any way to turn off the soap sucker when not in use? It makes sense that it would be sucking air when not in soap/vinegar. I don't see an obvious valve; I might have to resort to RTFM.
                          • Bill Stock
                            • 186
                            • Canada, Eh!
                            Originally posted by scmhogg
                            Bill,
                            Steve
                            Ah, that looks like the ticket. Thanks Steve.
