Due for a new grill, anyone know about this one?
  • Russianwolf
    • 3152
    • Martinsburg, WV, USA.
    • One of them there Toy saws
    http://www.lowes.com/lowes/lkn?actio...050&lpage=none
    anyone have one similar and care to share. I'll probably get the side fire box to go with it.
    Lakota's Dad
  • toolguy1000
    • Mar 2009
    • 1142
    • westchester cnty, ny
    check the specs. one of the items it shows is:
    UL Safety Listing: No
      The CharGriller is made by a company in GA. The metal is much heavier than most of the others on the market.
      I can't speak for the propane side but their charcoal grills are good. I have the Patio Pro model which is a grill made from the fire box used on the larger models. We also have one of their smoker grills at work.
      I called them for info on that model I think they said the burners are cst iron instead of the stainless steel used by most others. Had I not found a good C/L deal on a Jenn Air, I would have bought the one you are looking at.
      The biggest problems with most of the imported grills arethat the SS used is low grade/clad over a base metal and the models change every year so parts support is virtually non-existant.
      • master53yoda
        • Oct 2008
        • 456
        • Spokane Washington
        I bought it about 3 weeks ago and have used it a number of times.
        I added the side firebox to make it a Texas BBQ .
        the gas side is the fastest hottest BBQ i have ever used It will bury the needle on the thermometer and burn off all the drippings in about 15 minutes. It has 3 burners in the area that most have 2. It is very even on the heat and the shape is more accommodating because it is deeper then most. I cooked 15 hamburgers on it at one time and could still turn them etc. without any problems.
        The texas BBQ side is why I bought it in the first place as I have wanted to do indirect cooking for a long time. I have done chickens, ribs , and a bunch of turkey legs in it. I have found that it takes wayyyyyyyy longer to cook anything indirect but the taste and moisture level is better then any other way I have cooked. It also smokes items very well.
        MY .02 worth I would deffinatly buy it again.
        Art
