Bandsaw project for you
  • Tom Slick
    • 2913
    • Paso Robles, Calif, USA.
    • sears BT3 clone
    next time you're goofing off in the shop
    http://www.dailymotion.com/video/x8s...andoval_people
  • smorris
    • Apr 2003
    • 695
    • Tampa, Florida, USA.
    I think if I moved that fast on the band saw there would be finger parts laying around.
    • vaking
      • 1428
      • Montclair, NJ, USA.
      • Ryobi BT3100-1
      I have seen this process in real life, not in the video. A vendor at woowdworking show made a smaller version of such deer right in front of me. It took him probably less than 2 min of cutting, no marking in advance. He must have done a thousand of deers practicing. Interestingly - except for size it was basically same figurine. What caught my attention - the guys seemed to have ignored rules of minimum radius. At least it seemed that way. I must say it does work as demonstration of blade quality. I do have a blade from this guy (Olson All-Pro).
      Alex V
        That was cool, but can he cut in a straight line?
        • ironhat
          • 2553
          Seriously, though, how is that done with without snapping the blade. With a 3/8" blade onboard I'm a huge chicken at making sharp angles(well, sharp for me at least)!
          Blessings,
          Chiz
          • Tom Slick
            • 2913
            • sears BT3 clone
            that blade is at max 1/4" and you'll notice he gets the blade in a pretty good twist. with blades that small you don't really use any guides on the sides of the blade because you aren't really looking to cut straight lines.
            • Alex Franke
              • Feb 2007
              • 2641
              • Chapel Hill, NC
              Wow -- that's awesome. Thanks for sharing!
              ROFL!
              • sweensdv
                • 2873
                • WI
                • Baileigh TS-1040P-50
                I watched that video about a half a dozen time and then tried to duplicate what he did. Here's what I ended up with
                  Also have seen this done at a WW show. I'm sure it takes much practice to perfect. I wonder how many headless reindeer ended up in the scrap heap?
                  • thestinker
                    • Oct 2005
                    • 613
                    • Fort Worth, TX, USA.
                    Watching it is cool, but if you just had a bunch of the "headless" dear lying around, it would make for a better conversation starter.
