that occurred to me this afternoon. I know cement hardens as the result of a chemical reaction with water which is why it hardens underwater. Anyhoo, why does too much water make for a weaker mix?
A Cement Question
Being the son of a civil engineer, I would have been yelled at for asking this question in this way. Technically cement is a component of concrete, which is the substance to which you are referring. This has become a common place error, where people use the terms interchangeably. Here is a decent article on the chemistry involved.
http://chemistry.suite101.com/articl...ry_of_concreteKeith Z. Leonard
Go Steelers! -
I know that. I was actually thinking as I typed the post that I need to make sure and say 'concrete' instead of 'cement'. That being said, I am tired. It's been a busy weekend.Being the son of a civil engineer, I would have been yelled at for asking this question in this way. Technically cement is a component of concrete, which is the substance to which you are referring. This has become a common place error, where people use the terms interchangeably. Here is a decent article on the chemistry involved.
Thanks for the article. I think the answer is that less water means less space between the pores of cement and hence a stronger mix.David
This is precisely why they strength test most major commercial pours. They fill up little shots or cylindrical containers for testing later on. This is how they certify that a slab is poured to design specs.
Just like making a cake, if you don't follow the recipe correctly, your results will vary.
Cement itself will harden with a water mix, so you weren't all that far off base. Just not quite the mix you were looking for.
We usually dressed up our concrete curbs with a portland cement slurry applied over the top of the concrete. This gave everything a smooth even color.LeeComment
I was told that calling concrete cement was the same as calling bread flour when I was 18 and I have never forgotten that little quip.
