On Sunday I was switching gears from cross-cutting hardwood boards to ripping some redwood 2x6 for a yard project, and accordingly exchanging the 60T Dewalt blade in my 21829 with a new 24T ripping blade which had never before graced the arbor.
After mounting up the new blade and snugging the arbor nut (remounting TP, lowering blade, etc.), I started to feed my first 2x6 - and after about an inch of kerf, the blade slowed and stopped! (After turning off the saw) I immediately pulled the piece back, and on start-up, the blade resumed motion. I mentally ran through the litany of what I could be doing wrong - feed rate, alignment to fence, etc - and cautiously began to feed the piece again - and this time, the blade slowed and stopped even faster than the first time! Out came the workpiece again.
I began to worry that my 2-year-old saw was already developing motor or belt problems, or perhaps there was a defect in the carbide on the blade, so I shut off the saw, and noticed that the blade kept spinning WAY longer than it ever had in the past - and my panic about motor problems is skyrocketing. After unplugging the saw, I fed a sacrificial piece into the still-spinning blade to stop it, which worked - only to discover the blade was very slightly wobbling! - not as if warped, but as if the arbor bearings were shot. (now groaning in dismay.)
So I removed the TP, and wiggled the blade to see what was going on, and discovered the once-snug arbor nut was now loose, allowing the blade to wobble on the arbor. Boy did I feel sheepish.
What I failed to notice was 1) a little factory paint in the blade's arbor hole had prevented the blade from properly seating against the inboard arbor washer when I originally mounted the blade, and 2) that when the blade stopped during my cut, the motor was actually still running. Apparently, during my first cut, the paint broke free, allowing the blade to seat deeper onto the arbor, releasing the tension on the outboard arbor washer/nut, allowing the blade to spin freely on the arbor.
I re-snugged the nut, ensured a good grasp by both arbor washers, and got back to work - ripped the 2x6 like butter, no problems.
Lesson learned - always check that the blade is properly seating, even if the arbor nut feels snug when tightened.
