You have to be really careful using chemicals like that. I assume it is a flocculant that helps small particles bond together into something large enough to be filtered out. They can also cause gills to stick together and suffocate the fish. It is best to find the cause of the problem and then eliminate that. For slight cloudy hazes I have a Magnum HOB canister filter that has a micron cartridge that I sometimes use for water polishing but never will I use a flocculant in one of my tanks.
(I was a fish geek long before I was a computer geek or wood geek.
