To stop sofa from moving
  • radhak
    • 3061
    • Miramar, FL
    • Right Tilt 3HP Unisaw
    My living/family rooms are tiled, and the sofa/couches in both keep sliding around. Any suggestions on what works to keep this from happening?
    I cut up a pilate mat and placed small pieces under the legs, and it worked, sorta, for some time, but not satisfactorily.
    Google threw up this http://www.floor-protection-resource...75-Gripper-Pad
    But looking closely it says 'reduces furniture movement', so may it only works so-so?
    Anyway, what do you think is the material for it - maybe I could just make some at home? Ordering seems a hassle; might check out HD for something.
    - Aristotle
    I wonder if that high friction tape would work?
    http://www.leevalley.com/wood/page.a...at=1,110,43466
    Still have to order it though.
    Could just spill some coke on the tile, everything sticks to that.
    • catta12
      • Jan 2008
      • 250
      • Reno, NV
      • BTS20R
      Pocket screws and epoxy. Jk
      I have seen these listed before, no idea how well they work:
      http://www.suspendease.com/stopslides.html
      If you can read this you assembled wrong.
      Alan
      • radhak
        • 3061
        • Miramar, FL
        Tell me about it - that might be an idea!
        Apropos of that, an anecdote : once i needed a soda and the 'fridge was bare. I did not want a warm one, so I just dropped a sunkist can into the freezer 'for a minute'. Well, the neighbor came in to borrow a tool and I went over and forgot all about the can in the freezer. Much time later LOML heard a loud pop sound and opened the freezer to see that the can had burst and spilled orange soda all over inside the freezer, and also on the kitchen floor etc . Took me a week to clean that up, and forever for her to stop mentioning it . So I know the longevity and stickiness of soda on tile!
        Alan, that link might work - claims "even jumping into the Bed, Chair or Couch will not move it!" ; but it does look like plain rubber, maybe i should get some of that from HD . (yeah, i cannot stop thinking of making instead of buying).
        - Aristotle
        • Tom Miller
          • 2507
          • Twin Cities, MN
          How about cutting up a mouse pad -- the old style that are 1/2" thick? Hmmm, maybe they only have those in museums anymore.
          How about double-stick foam tape?
          Regards,
          • catta12
            • Jan 2008
            • 250
            • Reno, NV
            • BTS20R
            You might try that non-slip shelf lining stuff. It looks like knit but is made of rubber.
            http://www.americanvan.com/catalog/s...fm?FamilyID=39
            You can also pick it up at Wally World.
            Alan
            • herb fellows
              • New York City
              How about an old piece of router pad? Or a snippet (what's a snippet??!) of 'carpet holding stuff'? (that's the technical term!)
              • Salty
                • 690
                • Akron, Ohio
                How about Plasi-Dip!
                • vaking
                  • 1428
                  • Montclair, NJ, USA.
                  • Ryobi BT3100-1
                  I am not sure from the post but if your sofa/couches are sectional and you want them to stay together - there is a product called sofa snap.
                  http://www.sofasnap.com
                  I use it, works well.
                  Alex V
                  • DaveS
                    • 596
                    • Minneapolis,MN
                    I just lay on mine - very still - usually with the remote.
                    My wife asks me what I am doing, I saw "keeping the couch from moving."
                    • jfuselier7@centurytel.net
                      • Oct 2008
                      • 10
                      slides
                      looking for a cheap solution?? try the kitchen drawer inserts,, they look and act similar to router non-slip pads!! in fact I use these instead of the expensive pads!! I get mine in dollar general or family dollar. don't know how they will work on real heavy stuff like a sofa though!!
                      • radhak
                        • 3061
                        • Miramar, FL
                        Think I'm gonna try all the suggestions sequentially; I have a bunch of old kitchen inserts that I could try rightaway.
                        Dave, I think if I tried your method, I might get to sleep on the same couch as a reward...
                        - Aristotle
