URGENT computer question/problem
john, thanks a bundle!!
the white goo was real sticky, but i removed all the extra on the outside of the chip and the thin blade slid under the corner of one side of the chip and then all of a sudden it popped off the heat sink! phew, man i was scared silly that i had messed up!
So there's still white goo between the chip and the heat sink then right? Doesn't need much- just a thin smear- but it's there to help transfer the heat out of the chip into the heat sink.Comment
You Bet!
i am thinking that when i was applying some lateral pressure and the chip wont budge, there was 'over flow' of this goo from the sides. that extra goo was real sticky and may have had a part in not letting the chip off the heat sink. so i just removed the extra on the out side.
i did not remove the goo from the top of the chip or the heat sink where the chip is going to set. there seem to be plenty of goo left on the chip and underside of the heat sink, so i am thinking that there is plenty left to transfer the heat._________________________
omarComment
Just to be on the safe side, you probably should monitor the temperature of your cpu since you did not apply new thermal heatsink grease. Since you are using an AMD processor, you can do a Google search for a program called "core temp". It is a free program and will give you an instant reading for both cores. (It will not work on Intel processors).
Depending on your motherboard, you also may have software to monitor the CPU temperature. Finally, you can check the CPU temp by going into the BIOS if you are comfortable doing that. The easiest way is to just use Core Temp.
I have an AMD 6000+ and my cores are running 42C and 32C and are not overclocked. If your CPU is running about the same or maybe a little hotter you should be okay. If your temps are running 75-80C that's way too hot and you will need to remove & heatsink, remove the old grease and apply new, and reinstall.
A bad seal between the heatsink and motherboard could cause the CPU to overheat and could damage it. Most motherboards will shut down if the CPU gets too hot.
BobComment
