What kind of RAM do I need
  • jussi
    • 2162
    Anyway to figure out what type of RAM a mobo takes without opening up the case? And how many slots are left?
  • Alex Franke
    • Feb 2007
    • 2641
    • Chapel Hill, NC
    I would look up the motherboard brand and part number (should be on the motherboard, but it's hard to check without opening it), visit the manufacturer's web site, and check the manual. Even if you end up with RAM that fits, there might be other restrictions the motherboard has on RAM (e.g. same size in slots 1 & 3, or 2 & 4, or up to XGB in slots 1 & 2 with slots 3 & 4 empty, blah, blah, blah).
    • viking4949
      • Jan 2008
      • 54
      • Northwest Indiana
      • Craftsman 22811
      online tests
      Go to memorygiant.com or crucial.com and download/run their scanner, it will tell you what you have, and what you can upgrade to, as well as what it will cost.
      Brandon
      • Stan
        • 966
        • Kalispell, MT, USA.
        • BT3100, Delta 36-717
        I often use a hardware information tool called AIDA32, very good at identifying info such as you are looking for. Link below:
        http://www.sofotex.com/AIDA32-download_L9326.html
        http://www.elksigndesigns.com
          If you know what model # and manufacturer you can find out what kind you need. If there is a BIOS setup that should also tell you what memory is in what slots.
          • Wood_workur
            • 1914
            • Ohio
            • Ryobi bt3100-1
            http://www.cpuid.com/cpuz.php
            It will tell you what ram you have in it now and how many slots there are.
            Alex
            • shoottx
              • May 2008
              • 1240
              • Plano, Texas
              Here is a great place to look
              http://www.sheep101.info/breeds.html
              • jziegler
                • 1149
                • Salem, NJ, USA.
                I'll second using Crucial. If you know the MB model, you can do it on the web. Otherwise they have a system scan tool that will tell you all you need to know. They are a good place to order from, and sell quality memory.
                • billwmeyer
                  • 1868
                  • Weir, Ks, USA.
                  Mike, that was BAAAAAAAAAAAAD.
                  • shoottx
                    • May 2008
                    • 1240
                    • Plano, Texas
                    I guess it took someone from Kansas to understand the joke
