Has anyone had a problem with the fuel siphoning from the tank when the trimmer is not running?
On mine, which is a Homelite and runs great, if I don't loop the blead line so it is above the tank, it will sit there and drip fuel. It seems to be siphoning it from the tank. Is there supposed to be a check valve in the carb to keep that from happening?
