Yet another computer question
    I have an external hard drive. The user guide says if you want to disconnect the drive, click on the "safely remove hardware icon" in the system tray. I remember seeing it there before, but it's no longer there. How do I get it to appear again??
    edit: I should have told you I'm running Windows XP.
  • BobSch
    • 4385
    If you look at My Computer, can you see the drive?
    Is the drive powered on and is the USB cable plugged into the PC?
    If you can't see the drive, your machine doesn't know the drive is there.
    If you've re-booted your PC since the last time you've used ithe drive, power down the PC, unplug the drive, re-boot and plug it in again and the arrow icon should appear in the system tray.
    Bob
      I can access files from the drive, so that's not the problem. Is it OK to plug in the USB cable when the computer is running? Just want to make sure because it's a pretty new drive.
      • jonmulzer
        • Dec 2007
        • 946
        • Indianapolis, IN
        You can plug it in while the computer is on no problem. USB drives are hot-plug capable. In your system tray, at the left side of it, is there an arrow pointing to the left? If so click it to reveal any hidden icons.
        If not, let me know and I will search around to find the other, slightly more involved, solution to your problem.
        • just started
          • Mar 2008
          • 642
          • suburban Philly
          In 'My Comp" right click on the drive icon and select remove device. That has the same function as the sys tray icon. All it does (but VERY important to do) is make sure all the data in the cache is written to the drive and files closed before disconnecting the drive.
            Thanks for the quick help, guys. I shut the system down, unplugged the USB cable, started the computer up again, and plugged the cable in after it booted up. Everything looks like it should now. Thanks again the the help.
            • parnelli
              • 585
              It's possible that the drive policies changed for that drive. If you go to device manager, right click on the drive, and then go to the policies tab, you'll find the options for caching and removal for that drive.
              • jonmulzer
                • Dec 2007
                • 946
                • Indianapolis, IN
                That won't cause it to not show up in the system tray. All that controls is caching policy.
