could a woodchuck chuck if a woodchuck could use power tools?
How Much Wood
How Much Wood
47The same as if he didn't have any12.77%6None, he's too busy buying tools to use them.23.40%11None, he's too busy building jigs for his tools.27.66%13None, he's too busy arguing on the web about the best way to use them.36.17%17David
The chief cause of failure in this life is giving up what you want most for what you want at the moment.Tags: None -
Does he get to use a power chucker?
EdDo you know about kickback? Ray has a good writeup here... https://www.sawdustzone.org/articles...mare-explained
For a kickback demonstration video http://www.metacafe.com/watch/910584...demonstration/ -
No power tools...he's a neanderchuck.Happiness is sort of like wetting your pants....everyone can see it, but only you can feel the warmth.
Plus, being unionized, the union has set a quota so the 30 year chuckers don't look bad.From the "deep south" part of Canada
http://richardspensandthings.blogspot.com/Comment
Actually he's at a stand still, the ground hogs are hogging all the ground.
How much ground could a groundhog hog if the ground hog had a backhoe?
regards,
Charlie
Rudyard KiplingComment
Only if he could use FestoolJon
techzibits.comComment
Well; "a woodchuck would chuck all the wood that a wood chuck could chuck if a wood chuck could chuck wood..using power tools of course!"RuffSawn
Nothin' smells better than fresh sawdust!Comment
He could, of course be a clueless Chuck rather than a keyless Chuck
