Do you see a problem in the picture in this story?
  • Hellrazor
    • 2091
    • Abyss, PA
    • Ridgid R4512
    http://seattletimes.nwsource.com/htm...829_hay05.html
    I bet they have a mold problem
    But not a shred of mulch is outta place...
    • ironhat
      • 2553
      A mold problem? If they had mold they could at least use it for brains!! OTOH, around these parts when you see extensive combinations of downspouts leading to the front porch it's due to the use of a cistern. Moving here 25 years ago was my first experience with this method of saving water. Back to the brainless ones... they could pipe in the exhaust from the clothes dryer and invite folks over for a sauna and a soak combined!
      Blessings,
      Chiz
      • jonmulzer
        • Dec 2007
        • 946
        • Indianapolis, IN
        It needs to be posted here also.
        http://www.thisoldhouse.com/toh/phot...220600,00.html
        • cwithboat
          • Jan 2008
          • 614
          • 47deg54.3'N 122deg34.7'W
          • Craftsman Pro 21829
          I never said everybody in Seattle was as smart as Whaler.
          regards,
          Charlie
          Rudyard Kipling
          • JoeyGee
            • 1509
            • Sylvania, OH, USA.
            The house I grew up in had a large cistern in the basement, and it was filled by rainwater in a very similar fashion. It was not used by the time my parents moved in, but the space was still there.
            My parents' first house had a working cistern. My aunt and uncle lived in it until recently, and they still used it. It was odd to see a 5' wall in the basement filled to the brim with water behind it. As far as I know, it's still that way today.
              You haven't lived until you've been around a cistern that went septic. They build them into a lot of buildings down in the islands, because fresh water is very scarce there. I've seen entire resorts evacuated when the funk checks in...
              • sparkeyjames
                • 1087
                • Redford MI.
                Why yes I do see a problem. They narrowed the pipe at the bottom thereby restricting the water flow.
                • Tom Slick
                  • 2913
                  • Paso Robles, Calif, USA.
                  • sears BT3 clone
                  copper pipe touching steel pipe, Big Problem....someday
                    Of course there is a problem! That copper pipe is uninsulated and is sure to freeze and burst in the first cold snap...
                    • Duff
                      • 164
                      • San Antonio, TX
                      • Enco 12" RT
                      I had to check all 22 of the inspection found items on jon mulzers post. . .
                      I like the lightswitch in the shower. . . .
                      Enco 12" RT table saw(with router table currently added to right wing), Central Machinary 6" jointer, Delta 16" (17-900) drill press, Ridgid 14" bandsaw, Jet bench top Mortising machine, Porter Cable 6901 series routers (2) and a wide variety of Ryobi 18v tools.
                      • smorris
                        • Apr 2003
                        • 695
                        • Tampa, Florida, USA.
                        I grew up on a farm that had a large cistern that all the gutters drained into. It was about 15x15x6. We had a separate tap in the kitchen for that which was used for washing dishes, and other non-potable uses, it also fed the outside taps we used for hosing down stuff. I used to like going into the basement during storms and watching the waterfall into the cistern.
                        We also had an overflow cistern that was about 20x15x8, I don't recall ever seeing that with even any water in it but heard stories of how it used to fill up sometimes.
