Need advice
  • reddog552
    • Dec 2006
    • 245
    • Belleville Il.
    • Bt3000
    Need advice
    I have 2000' of 8" diamerer copper pipe,transmission line for tv radio.Its used line ie coroded green.I need to recondition it. bring the surface outside to a presentable product. The sections are 20' long. We can and do bring the inside to a BRIGHT HONED finish that is the criticle surface.I need to sand or buff the out side surface. ANY IDEAS
    The bitterness of poor quality lingers long after the sweetness of low cost is forgotten!
    While I am still looking for decent wire wheels, since I don't have a metal lathe (or one long enough for that), you might find this of use:
    http://home.comcast.net/~dpotts77/Re...umn_polish.htm
    I found it trying to refind how to refurbish my old 1948 Atlas drill press. Now I have a newer, floor model Atlas.
    • thrytis
      • 552
      • Concord, NC, USA.
      • Delta Unisaw
      I think a chemical approach would clean it up a lot faster than a abrasive approach. especially for the inside. Something like Bar Keepers Friend will take off light oxidation with next to no rubbing. With the amount you have to do though, you'll want to look around to find something cost effective.
      Eric
        Wow, I wonder what the replacement cost of 2000' of 8" copper pipe is... don't let the scrappers find that stuff!
        • Russianwolf
          • 3152
          • Martinsburg, WV, USA.
          • One of them there Toy saws
          No matter what you do to it, it will corrode again unless protected. What is the purpose that it needs to look good for?
          If it's to sell the product for it's intended purpose, it's a lot simpler to inform the buyer that the corrosion on the outside is in fact protective. Once the surface oxidizes, the material below is protected and not subject to further damage. That's why Copper roofing lasts in the 100's of years.
          Lakota's Dad
          • ironhat
            • 2553
            Tarn-X comes to mind but Mike has a logical aproach.
            Blessings,
            Chiz
              ...in a 55 gallon drum...
              Definitely go the chemical route. Most abrasives will ding up the surface, as copper is so soft. Maybe check with a roofing pro or high-end gutter contractor to see what they use. I know there are two distinct finishing methods for copper roofing. One is to let it turn green (patina) on its own, and the other preserves the new copper look with some kind of clear protective finish.
              • iceman61
                • Oct 2007
                • 699
                • West TN
                • Bosch 4100-09
                A method I use for cleaning copper & brass is a 0000 steel wool pad dipped in a lemon juice & salt solution. Works like a champ for me. I saw that on a Homer Formby show years ago. Another alternative is to just sprinkle salt on a lemon half & rub with that.
                Bottled hot sauce cleans copper very well also. If you have some in the fridge, put a drop on an old dark penny, let it sit a couple of minutes, then rub it off. If you let it sit for a couple of minutes it looks brand new.
