i want to buy a floor jack. i have a small mvp 2.25 ton jack. its ok, but its a pita to lift one side then the other .... but it doenst work well on my van because the frame is already like 12" off the ground.....so i want to get one.
should i get a 2.5ton or 3ton?
should i go for a brand name like craftsman or any other that you suggest?
should i buy new or used is fine?
if used, then what should i look for?
is the hf models good, because they will be less expensive.
thanks for all the input and advice.
