Malware infection
  • Handy Al
    • 416
    • Worthington, OH, USA.
    Malware infection
    I picked up a trojan malware program on my PC. It's called VirusHeat. It keeps popping up and saying I have spyware. It installed itself on the control tray.
    Everytime I try to run a anti-virus program , the PC reboots. I tried manually delete the files and registry entries (I found a list online), but I can't find any.
    I've tried booting up in safe mode and VirusHeat somehow gets installed.
    Has anyone have experience dealing this? I would welcome any help.
    "I'm growing older but not up." Jimmy Buffett
  • MilDoc
    Well, it can be removed manually but takes a lot of work and registry editing:
    http://www.wiki-security.com/wiki/Parasite/VirusHeat
    http://www.pchubs.com/blogs/virushea...move-virusheat
    Norton & McAfee should be able to remove it according to their web sites.
    Whether any of the free tools and scanners can remove it I don't know, even after a Google search.
      Try superantispyware (from www.superantispyware.com).
      • final_t
        • 1626
        Spybot: Search and Destroy is your (FREE!) friend.
        • smc331
          • Apr 2003
          • 1016
          • Charlotte, NC, USA.
          +1 on this little jewel! I used it three times in the past week to eradicate infestations on friends' 'puters.
          Another very useful utility I've recently found is TeamViewer 3 - it allows controlled access (password and session ID) through firewalls without having to create port and protocol rules - so I was able to do the above mentioned eradications from a remote location.
          Scott
          You can't be a real country unless you have a beer and an airline - it helps if you have some kind of a football team, or some nuclear weapons, but at the very least you need a beer. -- Frank Zappa
          http://macbournes.com
            Try Ad-Aware from Lavasoft - there is a free version. Also SpyBOT, both programs are good.
            • fbrend123
              • Aug 2006
              • 182
              • Michigan
              I've used this a couple of times, with good results:
              http://siri.geekstogo.com/SmitfraudFix.php
              • Handy Al
                • 416
                mitfraudFix did the trick
                Thanks fbrend123,
                SmitfraudFix did the trick. I tried all the others and the PC would crash half through the scan.
                This one was the only one I could run in Safe Mode with Command Prompt.
                VirusHeat is one nasty bugger.
