$1 photo/video image stabilizer
  • Alex Franke
    • Feb 2007
    • 2641
    • Chapel Hill, NC
    This is just genius. I'm temped to go out to the garage and make this right now.
    http://www.metacafe.com/watch/104194...se_the_tripod/
    It doesn't get much simpler than that. Thanks for the link. I'll do pretty well without it, but LOML could use it for sure.
    • footprintsinconc
      • 1759
      • Roseville (Sacramento), CA
      at least that is one project that you can start and finish by entering the shop once!
      it is a very neat idea. smart guy!
      omar
      • RodKirby
        • 3136
        • Mao Shan TSC-10RAS
        Way to go What a great solution
        Trust me - the older you get the more important this aid will be
        Downunder ... 1" = 25.4mm
        • jhart
          • 1715
          Pretty Slick solution. Will have to try it.
          • thrytis
            • 552
            • Concord, NC, USA.
            • Delta Unisaw
            That is a great idea! It is along the lines of using the camera strap wrapped around your arm to brace it, but i think this would be more effective. I think i'll make one for when i'm hiking and i don't want to carry a couple extra pounds of tripod.
            Eric
            • BobSch
              • 4385
              I've made those using a 1/4-20 eyebolt. Learned the trick from a photographer I used to work for. Sometimes you need a tripod, but for the rest, that's a lot esier to roll that up and stick it in your pocket.
              Bob
                As Bob suggests, this is an old field photographer's trick, though no less a good one. In other variations, when you're shooting from an awkward stance you can tie the cord to a tree limb or sign post or whatever.
                • germdoc
                  • 3567
                  • Omaha, NE
                  • BT3000--the gray ghost
                  It's a little too complicated for me. I usually prefer solutions that involve duct tape. (Didn't Red Green do something like this on his show once?)
                  Jeff
                    Jeff,
                    Just replace the string with duct tape then.
                    • cwithboat
                      • Jan 2008
                      • 614
                      • 47deg54.3'N 122deg34.7'W
                      • Craftsman Pro 21829
                      Great. Now make it work on my boat.
                      regards,
                      Charlie
                      Rudyard Kipling
                      • Alex Franke
                        • Feb 2007
                        • 2641
                        • Chapel Hill, NC
                        You could tie the string to the anchor!
