I Hate Plumbing
    I Hate Plumbing
    The assignment this weekend was move the washer and dryer (again).
    Working on the drain for the pump and....
    1. You only discover that one of your lines is 2" too short AFTER you've just been to the store for supplies because what you got last week in a vain attempt to preplan won't work.
    2. You also discover this AFTER you've plumbed the vent so you can't just move the pump.
    3. After getting everything all hooked in, you test it aaannd the friggin drain leaks at one of the old joints. Of course, yanking it around broke something.
    <edit> 4. Purple Primer stains. I know this because I almost fell off my ladder. I recovered but not before dragging the plastic I was using to cover some stuff down and the primer falling on the floor. I now have 1 purple sneaker and some toys (plastic of course) we were saving for the little one now have lots of purple spots.
    Jeez, that sounds like an awful project. Pump? I am assuming your units are in basement? What type of pipe are you working with?
      Since the drain line is non-pressure, you could probably use an epoxy to seal the leak in place. One thing I often do on plumbing projects is to double-buy fittings. Often, I will need them anyway, and if not, it helps me build up my fitting stock, so I maybe don't even need to go to the store next time.
        The reason I was asking about what type of plumbing you are using is, if its easy enough to cut the pipe, you can put a fernco in between the two sections of pipe (its a rubber slip cover with two worm clamps). This should give you some flexibility on the drain, if you use two fernco's you can even put in a trap to make clean out easier.
        • Cheeky
          • 862
          • westchester cty, new york
          • Ridgid TS2400LS
          ditto, and the next time i need them, they will have quadrupled in price.
          Pete
            Chopnhack, it is a Zoeller ejector pump. Comes as a kit. Works quite welll when things don't leak.
            The break in question is right at an elbow so no fernco fix. It is not really a break, just the joint most likely loosened up while I disconnected it and was moving it around. I thought about epoxy but will fix it correctly. Will cut it out and replace it. Fun Fun Fun.
            • docrowan
              • Mar 2007
              • 893
              • New Albany, MS
              Great tip! I buy extra sometimes with electrical, but for some reason plumbing aggravates me so much I get rattled at the store and just want to get my current project over with and don't give a hang about the next project.
              - Chris.
                David, you've been watching me too much when I do a plumbing job.
                • Sugarman
                  • Dec 2006
                  • 25
                  • Chester County, PA
                  I feel your pain. Your experience would be one of my better ones. l'd rather lick dirt than do plumbing.
                  • jhart
                    • 1715
                    I hate plumbing problems with a passion. Always ends up with at least 3 runs to the store it seems like. However, there is a plumbing supply store within a reasonable distance and they never fail to have the right part for old faucets, etc. My problem is figuring out what the right part is. A couple of times I have taken digital pictures of the problem in to them. Love those digital cameras.
                      Couldn't have said it better myself and that is why I didn't buy extra yesterday. I just wanted to get the darn thing done. Also for electrical, stuff like wire nuts, crimps, junction boxes etc work with different gauges of wire but plumbing I'd have to stock fittings for all different sizes.
                        David, you clearly have not been making your offerings to St. Bubba. Light a candle and go in peace, Brother.
                        • L. D. Jeffries
                          • 747
                          • Russell, NY, USA.
                          Someone ought to do a poll: "How much do you hate plumbing?" My answer would be; "I'd rather fight a junk yard dog then plumb ANYTHING!"
                          RuffSawn
