Last night, I finally glued the first two pieces of wood framework up for the Sea King project. It was just two small pieces of ply that will become the mount for the tail rotor gear box. I set the parts up on the work table, got my square out to be sure the parts were aligned 90 degrees to each other and applied a bit of medium thickness CA (super glue). Went out to watch TV for awhile and give the glue a chance to set up.
When I came back about an hour later, the parts looked perfect! I went to pick it up and discovered the glue had leached through the joint and my mount was glued to the table!
Fortunately, I had the parts sitting on a "building mat" and I was able to separte the parts form the mat without too much difficulty.
Sure gave my wife and mother-in-law a good laugh!
Now I use wax paper under those glue-ups. There are also many plastics that CA will not stick to, and all would work as well.
