When you tap into a dryer outlet, you are on a circuit generally fused, or breakered at, at least 30 amps. Your extension cord and lights are usually rated at 15 amps. If you get a short anywhere in the circuit, the wire will become your fuse. 30 amps at 120 volts is 3600 watts which is the equivalent of 3 toasters.
The code part is that you may not use wire (ext. cord) rated at 15 amps on a circuit that can provide 30 amps. I'm an electrical engineer (retired). I started a handyman company (Husband For Rent) 6 years ago and I do a good bit of wiring. My customers who have my work inspected have never not had the work approved.
A cheap sub-panel will make everything safe (BTW, in my state, all garage outlets must be GFI'ed, FWIW). I got a Sq. D. panel with 4 breakers (8 slots) for $48 at the home center for my garage. I used a 50 amp - 240 volt circuit that I put in for an old arc welder. I now only use a 120 volt MIG setup, so the 240 volt dryer-type outlet just took up space.
