I Deserve A Darwin Award
    This had to be one of those craft (can't remember a f&%#ing thing) moments.
    I got a new Ford Explorer Eddie Bauer, thanks to the input from you guys about suggestions. It has a two part rear door. The rear glass can be lifted by itself, or the whole door and glass can be lifted at once.
    Here's what happened. I've had to take one of my German Shepherds to the Vet several times since she fractured her leg. She is so energetic, that getting her into and out of the back has been a disaster. When getting her in, she wants to jump in as soon as it opens, and getting her out the same. Well, it opens enough for her to get going, but not wide enough or soon enough for me to control her. So, the other day I had a brainstorm. When putting her in, I stepped on her leash while the door was opening. When it was high enough, I tried to lift her in. She is about 80 lbs and not that big a deal lifting, but, I couldn't budge her off the ground. I put all I had into it and nothing. Tried again and thought I would bust a gut. Then, I realized I was still standing on the leash...duh. She had this look on her face that said "What's wrong daddy?
    When my wife got home I was hesitant about telling her how stupid I was, but told her anyway. Couldn't stop laughing.
  • charliex
    • 632
    • Spring Valley, MN, USA.
    • Sears equivelent BT3100-1
    It's called "bootstraping"
    • germdoc
      • 3567
      • Omaha, NE
      • BT3000--the gray ghost
      To really be a Darwin Award contender serious bodily harm has to be involved. So, fortunately, you're out of the running.
      On the other hand, you could be asked, "Where's your sign?"
      Jeff
        You mean like this one?
          Cabinetman, that's ok. I was on the mower today mulching up leaves and just about the time I thought I should be careful not to hit the 100' cord that lights the candy canes at the end of the driveway... well, now I have 2 cords - or will once I put ends on the pieces.
          • ragswl4
            • 1559
            • Winchester, Ca
            • C-Man 22114
            Not even close to a Darwin Award, but how about my latest senior moment.
            While building cripple walls for the garage I installed the studs (about 4.5 ft high) on the backend of the garage. Then installed a block between the two studs. Then remembering that I had left a crowbar under the garage I grabbed those two studs to pull myself up onto the foundation. I tend to move at a pretty rapid pace and if you haven't guessed it yet I pulled my head right into that block between the two studs.
            My next thought was, "What am I doing lying on the ground?" Yep, knocked myself right out. I have 3" of missing skin on the top of my head to prove it. I kind of gave myself a Mohawk haircut, but in reverse. I am currently blaming it on the ball hat that I was wearing. Lucky there wasn't a nail exposed. The shower I took that night was a real experience.
            RAGS
            Raggy and Me in San Felipe
            sigpic
              I"m making some built in cabinets for the basement. Since the basement walls are as straight as Capone, I have been framing the cabinets on the floor and standing them up in place. I was doing fine until I came to the last section-a small closet and shelf section. Seven feet tall. Fine until I went to stand it up under the 6"-10" ducting. Creative manuvering came into play.
              I'm getting my sign for Christmas.
                Hearing these "senior moments" reminds me of an escapade I had in my roof. I was single at the time and wanted to have cable at the other end of the house. So, I took a few tools with me up the scuttle into the attic. The cable was accessible at the East end (about 5' from the scuttle). Attached a new splitter and off I went to the West end, with a coil of cable, crawling on the rafters, being careful not to step in between.
                This was in July - August, and it was about 95+ degrees out at 10 AM. As I got closer to the other end, the roof pitched down and the rafters and joists tapered down to nothing at the edge of the roof. I didn't have to go that far, but almost. I had my tools in my back pocket, and as I crawled through while it was getting tighter, I got stuck. I couldn't back up, turn around, or go forward, because the tools got hooked on a rafter, and I couldn't reach around to get to them.
                Well, I thought that sooner or later I'd get found, Maybe dogs in the neighborhood will start barking due to the smell of a rotted body in the heat of summer. I stayed stuck for a couple of hours trying to get loose. I was sweating it out, literally. Kinda reminded me of some military training that I thought would kill me. What finally happened was, I got so sweated up and slippery, that I was able to get myself loose. I was just a bit too proud to start yelling for help.
                • cobob
                  • 252
                  • Rolla, MO, USA.
                  Brings to mind the Julie Brown lyrics
                  B L O N D
                  Don't you wish you were me
                  I took an IQ test, & I flunked it of course
                  I can't spell V.W. but I drive a porsch
                  cause I'm a blonde
                  yeah, yeah, yeah
                  I've always wanted to be a veterinarian because I really love children.
                  • pierhogunn
                    • 1567
                    • Harrisburg, NC, USA.
                    Cab, your story reminds me of the time I spent 14 hours troubleshooting a Solaris OS load that I couldn't get started, at hour 14 my team leader asked me to type out the command I was using to start the OS load
                    boot -net install
                    well the command is
                    boot - net install
                    that little space cost me a day, and quite a bit of pride at the office the next day
                    Monty Python's Flying Circus
                    Dan in Harrisburg, NC
